Originally Posted by pribbens
A little off topic, If you get a minute, perhaps you can give us a general description of where said fuse is located. Thanks
Not really off topic at all.
Do you have the touchscreen above the right side of the fridge to control everything?
The wooden panel above the fridge (app 10 x 16 inches) just to the left of that touch screen is held by a phillips head screw at each corner. Remove that panel and you will find a BUNCH of wiring (kind of a rats nest). There are a couple boxes mounted to the wall and one on the ceiling and a couple of loose electronic boards sitting among the wires (at least mine was). The one which controlled the hydraulics had 3 or four little square black boxes (less that an inch square) which I believe are relays. I could hear and feel on of these 'click' when I pressed the touchpad to run either the slide or the jacks. There are several fuses on that board. The green one, which is a 30 amp fuse is the one which was blown, and when I replaced it things worked fine.
Hope that helps. If I have occasion to open that panel again (I hope I don't) I'll take a picture.
Rick
