Originally Posted by TowPro
I found one line behind panel on DS where the pump is that turns down and goes through floor with a valve on it, but it looked more like a line drain.
Also It came with a tool to remove a water filter, but I have no idea where this filter is
The line with a valve that goes through the floor is the fresh water tank drain line. Don't hold your breath, though - it's just a gravity drain and takes ... well ... more or less forever. And I'm not sure how empty the tank really is once it stops dripping.
Unless they've moved it, the water filter is under the forward end of the rear bed. On mine, there are three small doors that open onto small spaces and the filter is behind the door on the street (driver's) side.
Dave
