Old 02-11-2016, 12:48 PM   #1
Talking Wimp Horn - Replaced
Although I don't use the horn maliciously, I was embarrassed for the last time while blowing the horn on the MB Solera. I put an air-horn on it and it now gets adequate attention. No I didn't get the biggest horn to over-compensate, but my choice is plenty loud with a nice two-tone sound.
This is the horn I purchased. It came with a relay. -- Robot Check
Here is how I did it.
  1. I removed the wimp horn under the grill on the front passenger side. I used the wires from the original horn to provide a circuit to the relay of the new horn. I spliced onto those wires and left the connector wrapped in tape. [RAP--reference attached photos]
  2. I ran those wires to the location of the new horn and relay.
  3. I then ran a new 12 volt wire from the main fuse panel inside the cab. [RAP] I used a trimmed connector to insert into the non-switched power strip spare fuse location. This was one end of an in-line fuse, the other end ran out through the fire wall at a nearby grommet penetration. [RAP]
  4. Then I fed the wire across the top of the fire wall and behind the windshield wiper motor assembly. Be sure to strap it well away from the mechanism. Then following the existing wiring harness I ran the wire that will feed power to the horn through the new relay. [RAP]
  5. I mounted the horn and the relay on the passenger side of the engine compartment just in front of the air filter hood, on the metal housing. [RAP] Then made the correct wire attachments to the relay so that the horn is driven by the new 12 volt power wire. I connected the ground side of the horn to the side fender adding a ring connector under the existing grounding post located there.
I hope you find this helpful so you too can get the attention of other drivers when needed.
Name:	Fuse Panel Conn.jpg
ID:	99384   Click image for larger version
Name:	Horn Connector Splice.jpg
ID:	99385   Click image for larger version
Name:	Horn Relay Wire.jpg
ID:	99386   Click image for larger version
Name:	Trimmed Connector.jpg
ID:	99387   Click image for larger version
Name:	Wire Firewall.jpg
Name:	Wire Firewall2.jpg
Rich H.
[/SIGPIC]
Solera 24R - 2014
Life is Good - All is Well
richhop25 is offline   Reply With Quote
Old 02-11-2016, 02:32 PM   #2
Nice write up!! I have been thinking of doing the same thing, using the same horn. I have installed that same horn on my motorcycle, too. They sound great with plenty of attention getting sound!!
Matt Smith
2016 Coachmen Prism 2150LE
Johnston, Iowa
capav8r is offline   Reply With Quote
Old 02-11-2016, 05:34 PM   #3
Just realized in 6000 miles I have never tested the horn!
2016 Sunseeker MBS
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 02-12-2016, 07:05 AM   #4
Loefflerh's Avatar
i have tested it once. Since that I am ashamed to use it....
Loefflerh is offline   Reply With Quote
Old 02-12-2016, 08:11 AM   #5
Mikegjax's Avatar
Why couldn't you use the original horn circuit and change the fuse size to higher amp. to account for the increased draw from the air horn? Current fuse is 15 amps. Just asking.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 02-12-2016, 08:23 AM   #6
nomad297's Avatar
Higher amp draw requires larger wire. Otherwise you could melt the smaller wire with a higher amp fuse not blowing at the right temperature.
Bruce
nomad297 is online now   Reply With Quote
Old 02-12-2016, 09:04 AM   #7
Mikegjax's Avatar
Bruce
I understand the higher amp draw factor, but what I am interested in is to find out if the normal wiring for the horn will handle 18 amps.
2014 Solera 24R
USN Retired
Old 02-12-2016, 09:38 AM   #8
AWG requirement depends on the length of the wiring involved. Here's a table for 12 volt wiring:
http://www.sunforceproducts.com/Supp...ctionTable.pdf
According to the table, 18 amps for 10 feet (seems like that ought to be enough?) needs 16 gauge wire. (If it's 5 feet or less you can get away with 18 gauge...)
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 02-12-2016, 10:02 AM   #9
The Stebel Nautilus horn draws 20 amps.
Matt Smith
Johnston, Iowa
Old 02-12-2016, 10:03 AM   #10
There have been a number of posts about the limitations of the horn circuit and the computer electronics on the MB. Seems some have had an issue with the computer recognizing a current draw larger than 15 amps as a major flaw. Most horns worth their screams are rated in the neighborhood of 13 to 20 amp draws. So, I took the safe avenue and used the horn circuit as it exists to pull in a separate relay (less than one amp). The relay that comes with the horn works fine in this application.
Rich H.
[/SIGPIC]
Solera 24R - 2014
