Old 09-06-2016, 06:07 PM   #11
Commercial Member
Warning
I have discovered some of the drain valves on my Coachmen are defective. I can turn the plastic handles but not all the valves open.
Even though these handles show the valves are open two are still closed
If I remove the handle to confirm. So far FR doesn't appear to care as I was 23 days past the 1 year warranty when I discovered the defective valves.
I write a blog on RV tire application and safety. RVTireSafety.com
Also give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
Tireman9 is offline   Reply With Quote
Old 09-06-2016, 09:29 PM   #12
Originally Posted by Rkloud9 View Post
Thanks for this info! I will print your response and add it to the FR manual, which does not mention this feature. The dealer may have discussed this at the PDI, but it is not in my notes. Do you think 2 gallons of anti-freeze is enough?
Bob & Cynthia
2017 SunSeeker MBS 2400W
Note - I did blow the lines out first - and only needed two gallons.
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 09-09-2016, 10:20 AM   #13
Don't forget about the outside shower/hose thing on the driver's side rear.
derrickc is offline   Reply With Quote
Old 12-08-2016, 06:39 PM   #14
Just drove my newly purchased 2017 Sunseeker MB 2400W from Florida to Maryland in time for our first freeze. I'm getting ready to drain the hot water heater, but the cheap plastic drain cap seems like it might have been rounded somewhat. 7/8" wrench is too small, but 1" seems a little big. Does anyone know the exact size?
BTW, I recently sold our boat and always winterized using compressed air for the fresh water lines. Efficient, no worry about antifreeze aftertaste.
Tall Guy is offline   Reply With Quote
Old 12-09-2016, 08:35 AM   #15
I always use a pair of adjustable ling handle plyers. I get a good grip and once it's started, I can turn it by hand. I use Teflon on the threads to seal with minimal torque.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 12-09-2016, 11:31 AM   #16
I think it is a 1" ... but you'll want to use a 6 point socket - a 12 point socket will round off the corners.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 12-09-2016, 02:40 PM   #17
It takes a 15/16 socket and I also use a 4 inch extension on my socket wrench. My W hasn't taken more than two gallons in the two years I've winterized it...seriously over bought that first year!
2016 MBS 2401w
Santos1060 is offline   Reply With Quote
Old 12-09-2016, 06:57 PM   #18
Mtnman64's Avatar
winterize 2400W
I'll receive my W mid January in London, Ky. I'll assume it will be winterized from the factory and I'll address all this come spring. It only made 32* here today in middle Tennessee. Has anyone ever been in this situation ? I don't have plans to travel till spring, but will run her around town for a while.
Mtnman64 is online now   Reply With Quote
Old 12-09-2016, 07:38 PM   #19
Rkloud9's Avatar
We picked up our W at the end of last March up here in Illinois. The motor home may have come from the factory with no water in the systems, but the dealer made everything work for the pre delivery inspection. When we drove it off the lot there was no water in the tanks, but the water lines were not cleared, and no anti freeze was used... the dealer felt that it was not necessary. The weather was pretty mild, and we took it up to Wisconsin and parked it. Two weeks later we headed out on our first trip, and when we started in was in the low 20's with about 4" of fresh snow on the ground. We filled it with water and beat feet South, and saw no more snow or freezing weather.
Seems like you should be OK in Kentucky in March, but if the cold persists, have the dealer winterize it while you are there for the PDI... you will learn a lot about your new W!
Bob & Cynthia
Rkloud9 is online now   Reply With Quote
winter
