-Solar powered fan for refrigerator.
-new controllable patio led lighting (not warrantied)
-added small 45 watt solar power kit to maintain battery power during power outages. (want to go full out solar)
Interior
-Hardwood Bamboo flooring living room and stairs with faux stone highlights.
-Hide-A-Way trash can.
-roll out trays in cabinets
Customizations
-stair case storage
-coffee bar
-built-in CD cabinets
-entertainment center (made to accommodate complete entertainment system, security system, computer and printers, and additional DVD storage)
Renovations and Repairs
Repairs I have made;
-replaced l/s tail light assembly
-repaired antenna crank assembly that fell off
-repaired front door stairs, loose, bolts pulled thru floor.
-repaired awning, ripped off side of RV with a short small breeze. not mounted to frame work, only fiberglass siding. remounted with extra support.
-AC not cooling entire RV, found AC vents leaking, resealed vent connections (still not cooling entire RV)
-Replaced leaking shower hose
-replaced propane tank hose
-l/s sofa has broken spring (not repaired yet)
-Patio led lighting inop, not warrentied, replaced with adjustable led light strip under awning
-cabinet shelf above main electrical wiring not mounted correctly and fell into main circuitry. properly supported and customized inside of cabinet
-all chandelier lights sticking in sockets when burnt out, disassembled, repaired and reassembled
-living room right side slide out, center window leaking water into window track. (not repaired yet)
-Freezer stopped working properly, added solar powered outside cooling fan and insulation to exterior wall, fixed
-traveling outside lights and brakes not functional, RV repaired by camping world, truck fixed by me.
Tow Vehicle
1981 GMC 3500 DOOLY, Sierra Classic, Camper Special, 454 CID, TH400 transmission, Gear Vendor, My dad was the Original Owner.
