25V owners might be interested in this. I was not pleased with the factory location of the TV and saw that the Grey Wolf 26RR (basically the same floor plan) had a much nicer setup.
The cabinet on the right as you enter from the main door is floor to ceiling. Since there is already plenty of cabinet space (at least for me there is) I decided to remove the top half. Easy job...just use a jig or recip saw. The cut doesn't have to be perfect because after you finish it you trim it out with "outside" quarter round trim and stain. If you make the cut flush with the bottom of the existing top door then after you add the trim it creates a one inch edge so you can throw remotes, keys, etc., on the new "top" shelf.
Here's a pix of the finished project (which took less than one hour to do).
