Originally Posted by Mr. Dan
... or maybe it's the switch. OR sometimes there are two switches in series - one on the wall and one on the fixture. If either are off, the fixture is off.
X2. True, the fixture you have has an on/off switch on the light, but.
If neither light is working, this may also be controlled by an on/off switch (or two)somewhere else in the camper. Look for rocker switches at your entry door down low, or at the main control panel where the A/C, water heater, etc. switches are located. The switch at the entry is to allow you to turn on an interior light when entering. This may also be a 3-way switch controlled at two points plus the light fixture. Reminder, if the fixture switch is in the off position, the light will not come on when the rocker switch is activated, so you have to flip the fixture switch when testing. If that doesn't work, you may have to remove the fixture and check for continuity.
As for the bulb, this is a T10 base light bulb. They can gently be rocked from side-to-side while firmly pulling out. As others suggest, it is a great idea to replace standard filament bulbs with LED bulbs such as the GRR T10 921. These come in a variety of brightness and from "daylight" to "soft" yellow hughes. The GRR series bulbs are shaped like a ping pong paddle and have a collar at the base of the LED disc. I use a kitchen spatula against the collar to seat the bulbs. I tried using the discs at first, but, they bend easily, but did not damage the bulb.
This, by a long shot, is not a dumb question. I have had considerable experience with electrical circuits and those in our unit had me baffled for spell. Changing out to LEDs is an excellent suggestion. They operate cooler, use minimal current, are brighter and will probably last for the life of the camper. The cost for changing out all of the fixtures to LEDs, including the bay lights, was $40 with a couple of spare bulbs if ever needed.
