Originally Posted by MR.M
The factory never installs enough fasteners . you'll need to get some self tapping sheet metal screws some fender washers and add double from what the factory installed . silicone around the entire edge and any openings you can use great stuff or something similar . I did my unit the first week of ownership . dropped the entire underbelly , added foam insulation , secured all electrical wiring and water lines . then reinstalled underbelly using the great foam around the entire edge before as i reinstalled then silicone around all edges and twice the number of fasteners . in 4 years towing across country in plenty of rain never an issue
I had my "underbelly" down while upgrading some wiring. Replaced the "Ramset Nails" with screws. Also sealed the edges with aluminum tape that is used to seal heating sheet metal work.
I worry more about an edge coming loose and catching the air at highway speed that will then rip the rest of the fasteners loose. Keep the air out and that risk is close to nil.
Put over 8,000 miles on the TT since this work and not a sign of any issues. BTW, towed in lots of rain too.
If securing the coroplast with silicone caulk/adhesive just remember that you may have to access the area behind it someday and the more permanent you secure it, the harder it will be to do so. Good screws with fender washers and an aluminum tape seal seems to satisfy both needs. Securing and still leaving future access.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
