Old 08-26-2016, 08:56 PM   #1
FrankG's Avatar
Vengeance 29V Upgrades
Got through with our upgrades for the year. We added a topper over the slide and the DW found a power couch to replace the provided dinette. What you can't see because the slide cannot be fully extended where the TT is parked, is the flush mount table leg holders I installed in the floor. This allows us to utilize the existing table for work space and still use the recliners.
Yes, I do my own modifications. Heading out on an extended vacation next week so we will see how it all works out.
ID:	118503   Click image for larger version
ID:	118504   Click image for larger version
2017 Laredo 325RL
2016 Vengeance 29V Sold
2013 F250SC 4x4 gas
Blue OX W/1500 lb bars - For Sale
2012 Spyder RTL - For Sale
FrankG is offline   Reply With Quote
Old 08-26-2016, 11:15 PM   #2
Was it hard to install the topper? Looking to add one to mine.
Tom
Tom McCrindle
2016 29v Vengeance Toy Hauler
tommc2000 is offline   Reply With Quote
Old 08-27-2016, 05:54 AM   #3
FrankG's Avatar
Tom
No, got a 8 ft. Solera Slider from CW online It came complete with all hardware. I just checked online and they do have a 8' 6" in white for $265.00. I would do an 8' 6" if I did it over again.
You will need a roll of 1" putty tape to put behind the rail and brackets. I put the awning rail (centered) about 1.5" below the top drip molding. The brackets that attach to the slider go inside the aluminum edge pieces. Not on the extruded aluminum. The instructions are not clear on this point.
All the screws found something solid under the aluminum skin to attach to. I used a power driver.
Good Luck
Frank
2017 Laredo 325RL
2013 F250SC 4x4 gas
Old 08-30-2016, 08:50 PM   #4
Info
What does the topper help with
Aztec1382 is offline   Reply With Quote
upgrade
