Old 09-04-2016, 06:43 PM   #11
No. They only come with the standard rubber stems made to handle up to 80 psi. My jackleg dealership didn't tell the tire shop to do it after I reminded them a few days before pick-up. Then, of course, I forgot to check to make sure they were metal stems at the PDI.
When we got home (276 miles away), I discovered the screw up a few days afterwards. When I called them, they talked to the tire dealer who told them they were the rubber high pressure stems. NOT. My G rated tires only had about 70 psi in them and when I pumped them up to 95, you could wiggle the stem slightly and air would come out around the seal. They were about to bust.
I took the camper to a local heavy truck shop and had them remove each tire and install all new metal stems. Took about an hour.
High pressure metal stems are cheap. Maybe $5 or less per stem.
By the way. That's the same wheels as mine. On the back is stamped in small print the PSI rating and load rating.
2015 F350 6.7L Lariat CC LB
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 09-04-2016, 06:48 PM   #12
Just FYI. My 40D12 with the golf cart, all our "stuff", and a full tank of generator fuel weighs maybe 18,000 lbs. or less. We really don't carry water.
I just wanted the G614s for the peace of mind and the speed rating.
2004 Puma 30FQSS
2010 Sabre 31QBDS
Old 09-04-2016, 08:47 PM   #13
mbbutler's Avatar
What's wrong with the Constance brand shown in picture?
mbbutler is offline   Reply With Quote
Old 09-04-2016, 09:09 PM   #14
Fulltime family RVer
Originally Posted by RVDon View Post
The booklet says 18,000 but it maybe up to 20-21,000 due to axle upgraded to 7K.
Here's the picture of the wheel. Do they already have metal valve stems, I didn't pay attention.
We can't see the stems in that picture.
So I assume their are 3 axles? I'd likely go for Sailuns or Goodyear (G614 not Marathons).
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 09-05-2016, 08:55 AM   #15
VaJim
Hercules tires
I replaced all of my cheap C rated Chinese tires with Hercules E rated tires and they are made in the U.S.A.
2010 Ram 1500 Quad 4X4 5.7L
2012 V-LITE 30WFKSS
VaJim is offline   Reply With Quote
Old 09-05-2016, 11:56 AM   #16
northstar1960's Avatar
Has anybody used these or heard good or bad. My dealer carries these and will replace my 7 E rated tires with these before picking up. $1023.00 for all 7 tires and I keep the brand new used ones with about 400 miles on them.
Hercules Power STR ST235/85R16 Overall Diameter: 31.73 in Fits Rim Size: 16 in Rim Width: 6.50 in Ply Rating: 12 Load Range: F Section Width: 9.250 Max Load Single: 3,960 lb Max psi: 95 lb
Says has a 36 month warranty on defects.
YESi use them they are a GREAT TIRE . have used them on my TV with over 80,000 miles and now on my XLR th so far over 8000 mile on the TH with out issues with many miles to go
northstar1960 is offline   Reply With Quote
Old 09-07-2016, 10:46 PM   #17
I found some s637 Sailun for great price but they have 235/80 and 235/85, should I stick with the factory size 80's or go with the taller size 85's which are the same specs other than 1 inch taller which also raises the trailer height. I figure the 235/80 will be little bit lighter, height will stay same plus little bit cheaper
RVDon is offline   Reply With Quote
Old 09-08-2016, 06:42 AM   #18
My G614s are 235/85/16. The height isn't a problem. Plenty of clearance between tires, too. The angle of the ramp is probably a little steeper but the golf cart goes up there with no problem. It sits perfectly hooked up to the truck so all in all, I'm pretty happy with the set-up.
2004 Puma 30FQSS
2010 Sabre 31QBDS
tire, tires, power
