Vengeance 39R12 Touring slide out ram leaking oil
I have the 39R12, the hydraulic ram for the slide out that holds the couch/chairs has been leaking but only when its closed not when its open. Just seeing if others have had same problem and what was wrong with it.
I took mine in to dealer under warranty and they changed ram out, took it home use couple times and its leaking again, its going back Friday for second round, I think the ram is not aligned right which put side pressure on seal which leaves oil seep by.
2015 Ram 3500 6.7 DRW
2017 Vengeance 39R12
