Old 03-19-2013, 05:18 PM   #1
Vengeance Toy Haulers
does anyone have one of these toy haulers that have a problem with the rear door I have a 2013 376 and the ramp door does not seal at the top I bet you could put your hand right in the gaps and I have not yet loaded anything in. I have taken it back to the dealer and they tell me that will happen and that maybe they could put thicker seal around the door. Do I just have to live with that or should it seal tight?
hommer is offline   Reply With Quote
Old 03-19-2013, 05:23 PM   #2
wyo700's Avatar
I have a sand storm and mine is not like that. And I would say no the door should not be that way on any toy hauler. Needs some adjustment
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is online now   Reply With Quote
Old 03-19-2013, 06:03 PM   #3
Oaklevel's Avatar
We have a 2013 Puma Unleashed the door is very tight all the way around...........sounds like something is not at all right !!!!!!!!!!!!!!
signhavefun:
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 03-20-2013, 12:40 PM   #4
thanks guys they are working on it I wil post back what happens
Old 03-20-2013, 01:40 PM   #5
Depending on how your door is held closed. Look at the clamp that holds the door closed. Mine had about a half inch gap between the door and the rubber piece that pushes against the door. I took the clamp off, 4 bolts holding the hinges. Then bent the hinge the way the that was needed to put pressure against the door. My hinge was aluminum and only took two wacks with a hammer. Only had to do my top hinge as the others were ok. Reinstalled the clamp and I was good to go. My ramp is held against the camper with two clamps, each with three rubber parts that push against the ramp door.
Sranch is offline   Reply With Quote
Old 03-22-2013, 10:14 PM   #6
We just picked up our 2013 306 Vengeance yesterday & just noticed the door issue this afternoon haven't loaded anything on it either. Please keep posted on what comes of this I'm disappointed with this issue
Harley Chic is offline   Reply With Quote
Old 03-23-2013, 06:15 PM   #7
dsrace's Avatar
if the doors don't seal then they leak and water damage is no good! do not stand for this and make them fix it!!
dsrace is offline   Reply With Quote
Old 03-25-2013, 02:36 PM   #8
trailer is still at the shop but I looked at some other toy haulers and the latch system on the vengeance is poor to say the least they might have to add some other kind of latch system
Old 03-25-2013, 10:29 PM   #9
jonnys_walkers's Avatar
Rear Door Bump Stops
Mine would not close tight either, so this was my remedy.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 03-26-2013, 02:27 AM   #10
Thanks that's similar to what we had on our other toy hauler might just have to try that
