In addition to keeping off skylights and vents, don't "stomp" on the roof. Walk somewhat gently so you don't "shock load" the roof.
Also be careful when washing the roof as a soapy roof can be "deadly slippery". Wear shoes suitable for walking on wet/slippery surfaces (like boat shoes) . Wash then rinse area well before moving so you can avoid soapy surface where you need to walk.
It goes without saying that you want to be aware of where the edge is at all times, especially if backing up.
Make sure you don't get your feet tangled in water hose or electrical extension cord if you're using one on the roof.
These are some things our local Fire Department has had to respond to over the years when people "exit the roof without using the ladder" so BE CAREFUL!!! When it comes to safety while on an RV roof a little "Paranoia" or "OCD" is a lot better than "Teenage Abandon". They "bounce" us older individuals don't.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
