Old 05-12-2019, 02:36 PM   #11
Why waste your time wondering if you will have enough truck when for pennies more you can upgrade to a 2500 then if you decide to upgrade you trailer you can do that without the worry of your TV. My nephew just bought a 2018 Ram 2500 with the 6.4 hemi with 4:10 gears and he actually can tow more and has more payload than my 2012 3500 diesel. Do yourself a favor and look at the 2500's you will be better off in the long run as the 2500's have a better suspension than the 1500's
No more shoveling is offline   Reply With Quote
Old 05-12-2019, 02:37 PM   #12
Canadian Member
I subscribe to a YouTube channel called “Love your RV”. Ray and his wife live full time in a smaller 26’ Keystone Cougar fifth wheel although he currently tows it with a 1 ton RAM. IMO there are very few 5ers that would not exceed a typical 1/2 ton’s GVWR but the size is doable as long as the floorplan allows for some separation time.
2019 Rockwood Signature 8290BS
Old 05-12-2019, 02:49 PM   #13
My DW drives our 3/4 ton ram shortbed diesel every day.
The mileage of the diesel is really good. Frankly they tow better for big trailers or fivers.
tomkatb is offline   Reply With Quote
Old 05-12-2019, 08:07 PM   #14
Bob43's Avatar
DW and I Winter in FL in a 26RR .. Lots of room
2017 GreyWolf 26RR
2009 F150 Lariat
Equal-i-Zer Weight Distribution Equalizer Hitch 12000#
2013 Honda F6B
530 Watts Solar on the roof
2000 watt Pure Sine Wave Inverter
Bob43 is offline   Reply With Quote
Old 05-12-2019, 10:40 PM   #15
We lived in a 27 ft Rockwood Ultralight for 5 years. We sold it when we settled in our current home and didn't consider camping again for 9 years. We towed it with a 1990 Ford F150. We had too much weight in the back of the trailer (in the bedroom under the bed), which created a weight imbalance and towing stability issues. We have many great memories of our time together in that trailer; it brought us closer together.
2015 Palomino SolAire 20RBS
2017 1500 Silverado LTZ Z71 with 6.2L, 8-speed & tow package
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days;
elchilero53 is offline   Reply With Quote
Old 05-13-2019, 11:55 AM   #16
We've got almost 37,000 miles on our Forest River Flagstaff Classic 8528RKWS towed with a 2012 Tundra. There is plenty of room for two of us and the dawg, and we've boondocked in the Montana mountains using a 3,500 watt inverter/generator without problems. It only runs one of the two AC units, but it was sufficient at that altitude. You'll find some folks will tell you an F-450 won't tow a grocery cart, but we've had no problems with the 9,000 lb. 5th wheel.
Trawlerphil is offline   Reply With Quote
Old 05-13-2019, 03:21 PM   #17
Canadian Member
Trawlerphil, I know your rear kitchen layout lightens the pinbox quite a bit. It's one of the advantages of that layout. FRF member OldCoot has the Rockwood version of your floorplan and I believe he's said the pin weight is only around 1000#. My new Rockwood 8290BS is also a rear kitchen floorplan. I'm curious if you've ever weighed your loaded trailer and found out what the pin weighs.
Old 05-13-2019, 04:06 PM   #18
I did weigh it with one of those hitch scales my friend bought. It came in at 1,520 lbs, but I'm not sure about the accuracy. I too specifically looked for an aft galley 5er.
Old 05-15-2019, 08:51 AM   #19
Roaminaround's Avatar
We do fine in a 30ft "half ton towable." 5 months a year and 4 months snowbirding. Pack carefully and don't forget lots of tools for repair and projects. My only issue was that I was overworking my old F150 ecoboost. It had Max tow option and plenty of power but lots of recurring issues including losing a front main seal this past winter. Dealers like to exaggerate what you should tow with a half ton. Do your homework. I've since upgraded to an F250.
Bend, OR
2019 Rockwood 2608BS
2018 Ford F250
Roaminaround is offline   Reply With Quote
Old 05-18-2019, 08:53 PM   #20
Your better half doesn't like the cold and we hate the heat of SE Texas. We go to the UP from mid May thru September.
whj469 is offline   Reply With Quote
« Golf carts | - »
