Old 11-04-2018, 07:45 PM   #1
Living in camper for the winter
Hi folks don't know if this is the right area.but here we go. We are going to have to live in our camper this winter. I need some ideas to winterize our camper so we don't freese everything up. We are in Minnesota so its going to get cold. Thank you in advance.
Retired
2019 Tundra 5.7L with tow package
2016 Shasta Oasis 26rl
PaPaMooseP is offline   Reply With Quote
Old 11-04-2018, 07:52 PM   #2
Minnesota? 1. park it in a heated barn. 2.winterize it and stay at a campground with heated bathrooms and don't use the water in your rig. 3. underskirting and every other possible option and still have it freeze up
Kimber45 is offline   Reply With Quote
Old 11-04-2018, 07:59 PM   #3
All the parks are closed for the season.so that option is out. Don't have access to a heated barn. And that's what we were thinking. Thank you
Retired
Old 11-04-2018, 08:03 PM   #4
clr
OK you will need a lot of preparation. You will need some type of skirting for the unit, I would suggest hay bales if you are allowed. You will need a heated and insulated water line. You will also need an extend a stay type of propane adapter, and I would contact a local propane company about on site service of a large propane tank. Placing plastic storm windows over the windows on the inside is a very good idea.
I hope your unit is 4 seasons and has some provision to remove the humidity, A humidifier may have to be purchased and used also.
Good luck and stay warm.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 11-04-2018, 08:06 PM   #5
Thank you very much
Retired
Old 11-04-2018, 08:19 PM   #6
bikendan's Avatar
The OP has a Shasta Oasis, definitely NOT a 4 season trailer.
Stick and tin trailer with only R-7 fiberglass insulation in roof, sidewalls and floor.
Not even a 3-season trailer.
Old 11-04-2018, 08:29 PM   #7
We did stay in it a few time last winter. But only for a couple nights at a time.
Retired
Old 11-04-2018, 08:31 PM   #8
sorry if my response seemed mean I was trying to be realistic. I live in Michigan and know hold cold it gets. I think Minnesota is prob worse. can you shower at work or the gym? and use buckets of water for toilet and bottle water for everthing else?
Old 11-04-2018, 08:34 PM   #9
KenHwy61's Avatar
As a fellow Minnesotan, I can tell you you are going to have some serious challenges but sometimes circumstances are what there are and moving south is not an option. Without knowing more details such as water supply, sewer waste disposal and type of electric supply it will be hard to give a specific answer. The Shasta was of never designed to be in sub-freezing, let alone sub-zero temps, but I am sure people have lived in far less and survived. As clr suggested, you will go through large amounts of propane and will have major moisture-condensation problems so a dehumidifier is a must. Any extra insulation anywhere you can add it would be beneficial. A carbon monoxide monitor is important to have. Be prepared to deal with frozen water lines and waste gate valves and give some thought as to what you might do if the furnace should fail.
Aviator Wright-Flyer#1908
1996 Holiday Rambler
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 11-04-2018, 08:38 PM   #10
I didn't take it as mean. We can use shower else where.we had thought about using a bucket.
Retired
Old 11-04-2018, 08:50 PM   #11
We understand we are going to have challenges. We also understand the Shasta was not designed for sub zero weather. And we never intended to do so. We are not able to go south.
Retired
Old 11-04-2018, 08:54 PM   #12
if you are not paying the electric bill get a couple inexpensive heaters from menards or lowes and run them like crazy.
Old 11-04-2018, 09:16 PM   #13
We will be paying the electic. But are considering using a couple small ones
Retired
Old 11-05-2018, 01:48 PM   #14
It's Cold
Insulated/Heated water line. If your holding tanks have the heating pads and a heated underbelly you can do it. You will have to skirt and will want to consider an electric heater in the storage area as well. Reflective/insulated covering on the inside of the windows keeps heat in as well as out. I also agree with the dehumidifier. Extra electric heat for the interior. Anything to block wind. (semi trailer from work etc).
Consider insulating any water line you can get to as well. Always leave a line dripping.
1984fireball is offline   Reply With Quote
Old 11-05-2018, 01:53 PM   #15
Thank you
Retired
Old 11-05-2018, 02:11 PM   #16
There was a Member on here a few years ago that "Tried to Winter in Minn"! Maybe someone can lead you to his "Post/Story" he was very Detailed on all his Prep Work even working with his Duluth,MN Dealer! They even Bought a Forest River "ICE HOUSE" to attempt staying during the COLD WINTER! It started out Humorous but turned VERY SAD at the end! You might try a Search at the Top under "Minnesota Winter Attempted"? Don't think or Hope for a "MILD WINTER" that never goes Well! Youroo!!
Old 11-05-2018, 02:14 PM   #17
Thank you. I will look for it
Retired
Old 11-05-2018, 02:22 PM   #18
There has to be another option for you. Living through the Winter in that trailer is only a notch above staying in a tent. A mobile home, apartment or staying with a friend or relative has to be better. Trade it off for something more livable.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 11-05-2018, 02:23 PM   #19
Here it is "GypsyFamily post on 10/19/2012! Youroo!!
Old 11-05-2018, 02:47 PM   #20
We just need to sleep on it
Retired
camper, winter
