Old 09-01-2014, 08:53 AM   #1
seasonal camping, jack supports and tire question
Im not sure if this is in the right thread but here it goes. So Amy And I decided to go seasonal next year we found a campground we love and I have some ideas on what to expect and what we will need to do for seasonal camping.. I do have a couple of questions though.. Besides the normal stabilizers should I use Jack supports?? If I should how many should I use, and where should I place them on the frame? Now on to the tires I plan On using some sort of composite material under the tires, what Im wondering is should I support the camper high enough so I can turn the tires on occasion.. My concern is the bearings.. Im worried about what will happen with lack of use.. thatnk you guys for any and all input..
Scrubby is offline   Reply With Quote
Old 09-01-2014, 09:50 AM   #2
Ford Idaho's Avatar
I would go with eight jack stands.
One on each corner and the other four in front of and behind the axles on each side.
I would put one or two of these under the stands to spread the weight out a little.
12 in. x 12 in. Pewter Concrete Step Stone-71200 at The Home Depot
As long as the bearings are greased I would not worry about them much.
camping, tire
