Old 07-15-2019, 01:19 PM   #1
Blue Ox Patriot Aux Braking System for Tow vehicles
Why buy new? Blue Ox is known for quality. This unit has only been used 2 times we no longer tow . Perfect condition! Super easy setup.Works on any vehicle. I have attached the description of item from the blue Ox website. Cash only. In town or you pick up Columbus GA I will meet within city limits. Don't miss this deal. These units are expensive, so take advantage of like new. Thanks for looking.
Patriot Braking System from Blue Ox gives you the comfort needed in a portable braking system when your setting up your tow vehicle. Not only is it convenient and easy to store, but it also proportionally applies the brakes smoothly while you're slowing down to a stop, instead of suddenly jolting your tow vehicle causing costly damage to your brakes. You get full power emergency braking or slow speed action with the same system. The Patriot ensures that the brakes in your towed vehicle are activated at the same time and with the same intensity that you apply them in your RV. The Patriot even works with Hybrids! All Blue Ox braking systems comes with a one year warranty. Includes: Patriot, Breakaway Switch, Breakaway Lanyard, 2 Way RF In Coach Controller, Brake Feet, Breakaway Cable and Breakaway Extension.Compatible with Hybrids! All electric! No pump, tank, or air hoses to leak No slamming of the brake, moves smoothly and proportionally Adjust the amount of braking from coach Manually apply brakes from coach with wireless remote Break away comes standard Electric actuator instead of air cylinder Built in battery 15 lbs! Half the weight of similar braking systems LED display on both the brake and remote control Convenient carrying handle Comes standard with on/off switch Easy self calibration with the push of one button Unique, easy to use brake pedal clamp Larger surface push pad on back of unit to seat Wrap around cleat on side for safe storage of plug wiring The Blue Ox Patriot Braking System is a vast improvement over "on/off" systems, which brake at a single pre set level, the Patriot has a proportional design for equal braking. The actuator inside your towed vehicle applies the brakes with the same intensity that you apply to them in your RV. If you slam on the RV's brakes in an emergency situation, the Patriot engages your towed vehicle's brakes with virtually the same intensity. If you press the RV's brakes just enough to slow a bit, your towed vehicle's brakes are depressed just enough to slow it down, as well. The result is improved control, better stopping and less wear on both your car's and RV's brakes.
View this ad at Forest River Classifieds - Blue Ox Patriot Aux Braking System for Tow vehicles
cinandsheri is offline   Reply With Quote
Old 08-06-2019, 10:28 AM   #2
Price
please send info and pricing to larry.pennington@roadrunner.com
Penary is offline   Reply With Quote
