Old 12-04-2019, 04:49 PM   #1
Relion Lithiom Battery Monitor and indicator NEW
Brand new, never used. New 125. Sell for 50.
See Relion website for details.
<h2>Real Time Data on Your Battery Bank</h2>The RELiON Battery Indicator is a high precision meter that captures instantaneous and integrated data in real time. Through the use of a 500A current shunt, the battery indicator measures the discharge/recharge currents and calculates the Ampere hours Ah flowing in and out of the battery. High precision voltage measurements are taken and displayed in real time through the use of a field installed sense wire. RELiON s Battery Indicator is well suited for lithium iron phosphate, lithium ion, lead acid and nickel metal hydride batteries. The battery indicator may be panel mounted and held in place by the bracket and butterfly nut and comes with a one year limited warranty.
[table]<colgroup><col /></colgroup>[tr]<th>FEATURES:
</th>[/tr][tr][td]Provides critical information about the status of your battery bank[/td][td][/td][/tr][tr][td]Displays voltage, current, consumed ampere hours and remaining battery capacity[/td][td][/td][/tr][tr][td]Works with one battery, series or parallel connections[/td][td][/td][/tr][tr][td]Suitable for traction/mobile and stationary applications[/td][td][/td][/tr][tr][td]Easy installation via bracket and butterfly nut[/td][td][/td][/tr][tr][td]LCD display[/td][td][/td][/tr][tr][td]Battery temperature sensor input[/td][td][/td][/tr][tr][td]Stores a rang of history through internal memory[/td][/tr][/table]
View this ad at Forest River Classifieds - Relion Lithiom Battery Monitor and indicator NEW
fstclyz is offline   Reply With Quote
