02-25-2018, 01:23 PM
38FB Electrical ???
Well we picked up our new home yesterday and got her down to SW FL where it will be until we sell our bricks n sticks. Did our PDI and everything worked as it should. Fired up the coach this morning and everything works except the TV, fireplace, on outlet in the bedroom slide. Checked the breakers and fuses and they appear to be ok. Any thoughts on what might be happening?
Thanks,
Pete
02-25-2018, 01:26 PM
Berkshire 390QS
Check your GFIs and also breaker on the inverter.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
02-25-2018, 01:45 PM
Thanks,
Checked those both no faults indicated.
The only thing different today is we are running on 30 amp instead of 50. All other 110 outlets in the coach are working.
Pete
02-25-2018, 01:53 PM
Do you have 3 a/c's with the power management system?
FROG AR-0019-242
02-25-2018, 02:11 PM
Yes,
3 ac units. I am only running 1 ac, fridge and a tv and ceiling fan.
02-25-2018, 02:47 PM
clarify: you say 'fired up the coach this morning....', does that mean the Generator(?), but then later said that you are on '30a' service? Which is it? Which ones exhibits the problems?
The Turners...
02-25-2018, 02:52 PM
Location: Alberta - East of the Rockies, West of the Rest
When you look at your breaker panel are the breakers for the effected systems all on the same side either left or right of the 50Amp main breakers? If yes that could mean that the 30 Amp is not properly feeding both sides.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
02-25-2018, 02:55 PM
We are running on a portable 4500 Champion dual fuel to test everything out. I will try the Onan 5500 to see if that makes a difference.
Thanks,
Pete
02-25-2018, 02:56 PM
Yes they are. I will try switching to the Onan 5500 onboard generator to see if that makes a difference.
Thanks,
Pete
02-25-2018, 03:12 PM
Thanks,
Pete
Update,
All is working now, fired up the Onan and everything is working as it should.
Thanks,
Pete
02-27-2018, 03:51 PM
I am very curious in this topic.
Why did this circuit not work on 30Amp? Are different parts of the coach on different legs of the 50Amp? Is it because the 3rd AC is installed?
Thanks,
Kirk
