07-09-2018, 09:32 PM
38RE basement door latches and strikers
Have any of you with the Legacy 38RE basement doors experienced looseness of fasteners, misalignment of the door latches, and striker plates coming loose?
I started having problems with the rear basement door on the street side (under the living room) when loading the cavity just before leaving on a 2600 mile trip. The door latch would not unlock! Had to remove everything from the full width cavity from the curb side, then reach across with a long handled device to unlatch it from the inside. Turns out the plant installed screws with tapered heads (I believe similar to a Phillips flat head machine screw but with a tapered head to the threads; see picture below). These screws were mostly all loose on all four doors, allowing the latch to move around and come out of adjustment on the problem door. IMHO they did not provide enough seating surface against the latch housing to stay tight.
I replaced the tapered screws with Philips pan head SS screws and used thread lock (nobody uses the term Loc-tite in the big box stores) to keep them tight.
I then realized that the plant installed three different types of latches on all the basement doors. One design was used on the rear basement doors (those were all loose, so I replaced all the fasteners). The side basement doors had another design latch with pan head square recess fasteners with a flat seating surface. The front basement latches were still another design but did have the pan head square recess screws!
It looks to me that the plant ran out of intended screws when they were assembling, and used whatever else they could find with the right length and thread count.
You may want to check your latch fasteners for tightness and design consistency. These latches seem to be very sensitive to adjustment for proper latching.
I now have one rear basement door striker plate that is loose from its mount. The striker plates are riveted in place so may have to have that done under warranty. That particular door will not latch properly, but can be locked by slightly moving the latch handle and then turning the key.
So, my questions to other 38RE users:
1. Do you have the same design fasteners in all of your basement doors?
2. If so, are they the pan head square recess fasteners that you would normally see in the RV industry?
3. Do you have the same design door latches on all your basement doors? (I have some with slots, some without, and some with a different design slots).
Sorry for the long post.
Noel
2018 1/2 Riverstone Legacy 38RE
2020 F450 King Ranch (traded 2015 F350 King Ranch)
TST TPMS, Rand McNally Overdryve 7RV GPS
2 Hobie Inflatable Kayaks
07-10-2018, 08:08 AM
Noel,
I do not have the issues with the latches on our 38FB2 you describe, I checked them just before we moved last week. However I did find that all of the screws holding the gas struts to the baggage doors were very loose. So loose in fact that a strut separated from the door mounted plate. After looking more closely there are 2 screws are driven into the outer metal trim of the door into the composite material and 1 screw in the center that only goes into the plate and into the door. These doors are heavy and the gas struts are putting too much pressure on these weak mounting fasteners. My solution was to remove all the door mounted brackets and apply 3M 5200 Marine adhesive sealant to the screws and to the brackets. I removed one side at a time and let the sealant cure for 24 hours before reattaching the gas strut to the bracket. Took a couple of days to do the 3 doors but now the mounts are rock solid. If anyone has any questions just let me know.
Pete
07-10-2018, 08:37 AM
38MB owner here and we had one strut break loose off the end with the round nub, factory replaced all our struts at last years FROG Rally because they started to use a lesser strength rods, I always felt the originals were to strong, as the door would come up so fast I didn't want the wife to open them for fear if caught in the chin and get knocked out I would get the blame
2017 River Stone Legacy 38mb
2001 Kenworth T2000
2016 Smart for Two on deck
07-10-2018, 08:44 AM
Are you saying that the strut broke the end of the mounting plate off? Or just that the strut came off of the tab?
Good idea changing to lesser strength gas struts, wonder if the factory would send replacements out so that I can change them myself?
Pete
07-10-2018, 08:56 AM
Pete
Just came off the tab. I believe they went down to 40lb struts ours were 60lb, I figured they would have to switch both on the door in question but ended up doing all 3 bays.
2001 Kenworth T2000
07-10-2018, 09:26 AM
Location: Alberta - East of the Rockies, West of the Rest
I just walked around the coach with a screwdriver, everything is tight. I noticed they used flathead screws on some latches and panhead screws on others, should have been all panhead IMO.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
07-10-2018, 01:35 PM
Upholstery head?
I believe the screws you illustrated are intended for use with what I call "upholstery washers." A Google search using the phrase machine screws with upholstery washers finds them. See the images I've included.
As to your conjecture as to whether they should have been used, or should have been used with the washers, I haven't a clue. I suppose it would have been better had your post included images of the three different types of latches.
Larry
07-10-2018, 07:54 PM
Larry
Here are the two different types of latches (but they all have the same type of housing where the #8-32 screws go but note the different slots and internal mechanisms). The first and the last picture still have the original screws installed (note the boogered Phillips heads). The second picture shows the SS pan head screws I installed. The last picture attempts to show how little contact there is between the flat head Phillips screws (the factory installed) and the latch housing.
07-10-2018, 11:58 PM
Pan heads are a good choice
I agree. Pan heads are a better choice.
Larry
07-16-2018, 06:02 AM
Thanks for the heads up on switching to 40lb struts. Changed out the factory 60lb for 40lb this weekend, much smoother and less stress on the mounting plates.
Pete
07-30-2018, 06:47 AM
Pete
Just had one strut come off the large basement door on the curb side this weekend when DW was loading up. The two screws in the metal trim can still be tightened, but the screw into the soft door material is loose and will not tighten up. Will have to figure out how to get that tightened. I am currently using just the one 60 lb strut and that works OK, but obviously would like one on each side.
Pete, did you have the factory send out the 40 lb struts or did you buy them yourself?
Noel
07-30-2018, 06:54 AM
Noel
Noel,
We purchased 4 new struts at a local dealer, think they were approximately $17 ea. I used 3M 5200 adhesive sealant on the door mounting plates and screws. It will hold up under repetitive use.
Pete
07-30-2018, 09:37 AM
Noel
I had this happen on our last trailer. I used nail plates like this one in the picture, cut it to size, scuffed up the back side and the spot on the door and used 2 part epoxy to glue it on. I screwed the bracket right onto it, you wouldn't even know it was there. It's probably best to do both sides, when one comes off the other one isn't far behind.
Ordered: 2021....
07-30-2018, 10:11 AM
Thanks, Cypressloser.
What did you do with the wallowed out hole in the soft door? I was thinking of using toothpicks glued in with Gorilla glue then screw through the toothpicks...Or did the nail plates have a small enough hole so the screw threads grabbed it?
Noel
07-30-2018, 11:22 AM
I simply epoxied the nail plates to the door and screwed the strut bracket back on with self tapping screws through the pre puncheed nail holes. I don't think toothpicks would hold long term.
Ordered: 2021....
08-03-2018, 08:10 AM
Cypress, I ended up doing something similar to the one side that had come apart, although I ended up using self tapping screws that were one size larger than the original (#12 vs. #10 IIRC).
Looking at the other side, I see more evidence of the plant running out of fasteners during manufacturing, since the other strut bracket on the side basement door has pan head screws holding it on vs. self tapping screws on the side that came apart. Will be doing the mod to the other side as well as inspecting the front basement door strut brackets. I believe the reason that the side basement door strut came apart was that the bracket sat on top of the metal trim, screwed down to the trim (2 screws) and door (1 screw) and was then installed on an angle with the main part of the door. Installing the nail plates helped to bring the bracket to be more perpendicular to the door.
Ordered four 40 lb struts to do both sides of the side basement door and front basement door. Will use the leftover struts to install on the bed for pivoting up. Strange that there are no struts on the bed for lifting now...my SOB fifth wheel had one on either side. Maybe related to the newer steel frame they just started to use on the 2018 1/2 models????? Anyway, storing anything under the bed is currently a two person job (I get to hold up the bed while DW stores stuff). The bed with the steel frame and no struts is HEAVY!
Noel
