I believe the purpose of the power management is to keep all three from starting at the same time. Any compressor or pump based appliance requires a large upfront draw to get started that in turn will cause a voltage drop. You've got plenty of amps to run all three together, just not good to have all three start at the same time especially with the potential for a fridge or two also starting at the same time.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
