We have a Wastemaster on our RS, anything twist on wouldn't work unless with an adapter. Installing different tank level sensors would be a lot of work considering the enclosed underbelly, insulation and 'what have you'. It's just not worth doing.
I know we can easily go 12 days, sometimes 14 days before the toilet burps, easy enough. After I dump I fill the toilet bowl a couple times all the way and let that splash down into the tank, I think it makes a much bigger impact than just using the black tank flush alone, the sensor usually goes right back to 0 after a few minutes.
We don't use chemicals or additives at all, just Kirkland TP and a spritz of undiluted dishsoap. However, there is a different issue that can arise, but I'll better start a new thread for that.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
