Old 06-20-2018, 10:55 AM   #1
Black water issues
We are new to the Full-Time RV life and I have a question about Black Water issues. Currently, our black water tank is stuck at 33% no matter what we do.
We have used the water sprayer inside to wash out the tank, used an additive to help break down waste, etc. We only use the recommended toilet paper etc. Any help would greatly be appreciated. Are we missing any steps, etc.
2018 Riverstone 39FK
jdmoody09 is offline   Reply With Quote
Old 06-20-2018, 11:00 AM   #2
Our 38FB2 has the same issues. We will be moving to a new location in a couple of weeks, have read that sometimes this helps with stuck sensors. After dumping our tanks completely they still read 33% on both black tanks and the shower gray tank. The kitchen gray tank will go back to zero. No solids have been deposited in our black tanks, only liquids so far.
Pete
Fishrsafe is offline   Reply With Quote
Old 06-20-2018, 11:00 AM   #3
cavie's Avatar
If your talking about 33% on the gauge forget about it. They seldom work correctly. Have new sensors added to the outside of your tank. If you have a straight shot down from the toilet to the tank, use a stick to measure. Think dipstick on your car.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 06-20-2018, 11:03 AM   #4
Just prior to driving add 20# of ice in the toilet and add a few curves. Calgon water softener, borax and dawn dish soap help but you need to drive a lot with tank filled with about 1/3 water.
Jack
jaherbst is offline   Reply With Quote
Old 06-20-2018, 11:07 AM   #5
Thanks everyone. I will let my hubby know. Appreciate all the tips and info.
Old 06-20-2018, 11:09 AM   #6
x2
It's probably a tank sensor issue and cleaning those sensors is difficult. You've done what you can... so don't worry about it. Most of us have learned to live with some problems with the sensors.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 06-20-2018, 11:15 AM   #7
Ejs4029's Avatar
Jack
How much Calgon do you use top treat the black water tank ? I think my tank is 37 gallons.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 06-20-2018, 11:32 AM   #8
brookstone345sa's Avatar
Try backflush valve
Name:	backflush fitting.jpg
brookstone345sa is offline   Reply With Quote
Old 06-20-2018, 11:59 AM   #9
SailorSam20500's Avatar
There are posts and u-tubes that debunk the ice idea. So I don't bother.
I use the liquid Calgon and Dawn. I use the cap on the Calgon bottle and put 1 cap full of each every time I dump the tank. Also add a gallon or 3 of water to the empty tank. I've gone back and forth a few times of having a sensor not read properly then get cleaned off.
I've looked at the See View monitor system mentioned above that mounts the sensors on the outside of the tank. But at $300-$500 plus the effort or cost needed to install, I've decided to live with what I have.
Al
Save the Earth. It’s the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 06-20-2018, 12:02 PM   #10
The sensors are notoriously inaccurate.
Unless you believe your tank isn't fully draining and leaving 1/3 in it, I wouldn't be to concerned with the gauge.
Do you use a clear elbow or extension at the sewer port on the side of your rig?
If so, you'll know whether it is draining.
Days Camped: '15=22 '16=46 '17=30 '18=51
black, black water, water
