Old 12-18-2018, 10:16 AM   #1
Floor Scratching From Slides
Has anyone experienced scratching on the floors due to slides being opened and closed? I've used my slides less than a dozen times so far and I can see scratches (beyond a normal rub mark) in several areas where all 3 slides move. I've been told by a couple of RV Park "experts" that the height of the slides can be adjusted, however I am leery of tackling it 1) due to lack of experience, and 2) knocking thing out of square. I was also told that due to having the upgraded Shaw flooring put in instead of the stock vinyl, the height may not have been compensated at the factory. I'd like to know if anyone has similar experience, and to know how hard it would be to adjust, as I have friends at the resort who are a lot handier than I. Thanks,
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 12-18-2018, 10:37 AM   #2
Brother Les's Avatar
Being a 2019, should be under warranty. Call the Dealer bought from and have him adjust it and have the dealer fix the floor.
Brother Les
Old 12-18-2018, 10:50 AM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
^^^What Brother Les says.^^^
Scuff marks are not uncommon and happen when the slide rocks a bit while going in or out, we have one scratch on the floor near the door and I'm almost certain it was caused at one time by a grain of sand.
We had the kitchen slide fixed and even though I'm very handy with tools (so I think ), this can be a complex job that I would rather have someone do who's already done it once or twice.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 12-18-2018, 11:25 AM   #4
Scratches are pretty common, especially with laminate flooring. As mentioned, sand and dirt have a tendency to scratch. My DW is adamant about sweeping those surfaces before moving a slide.
Gouging is not common unless you caught a rock or dropped something not knowing and it got wedged in there.
If you are concerned about the slides not being adjusted correctly and you have no experience in adjusting them, please find a qualified tech.
Things can go south in a hurry when mis-adjusting a slide.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 12-18-2018, 01:59 PM   #5
Just A Member
EDABEUT's Avatar
We had the same issue with floor getting scratched. LIppert gave us a pair of slide slickers at Frog Rally and they work great. Have to hold them in place until slide rails get on them and you might have to cut off the nubs on back used to hold in place on carpet. I just did a search and Walmart has them for $55.00 and Amazon has them for $48.00. I have had my super slide adjusted 3 times and it still rubs floor if it rocks when going in.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 12-18-2018, 02:22 PM   #6
Our kitchen slide did more than just rub and is under warranty and yet all we've been told is they will adjust the slide but to bad so sad on the damage it did to the floors...
2018 Salem Hemisphere GLX 300BH
1999 F250 7.3 PSD CCLB 2WD
MDCampingDad is offline   Reply With Quote
Old 12-18-2018, 02:35 PM   #7
DouglasReid's Avatar
X2 what he said^^^
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 12-18-2018, 03:27 PM   #8
Some dealers don’t have the skill nor inclination to work on flooring but then contacting the maker would be in order while it’s still under warranty. I’m with the others in getting an experienced tech to adjust the slide.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 12-18-2018, 03:49 PM   #9
Our fifth wheel is a 2004 model. We replaced the carpet with vinal peel and stick tile. I didn't want to tackle adjusting the slide. So avoid scratching I cut 4, 1ft squares of the old carpet. We place them upside down and let the slide catch them as it comes in. Works for us.
shadows4 is offline   Reply With Quote
Old 12-18-2018, 04:35 PM   #10
Get yourself two or four pieces of scrap carpet (maybe 6x6 or 12x6), put these down (make sure the soft side is down) where the slide hits the floor, that way the slides don't damage the floor, I had my slides adjusted multiple times by the dealer service and they made it worse, at one point the slide was moving back and forth as I was driving down the road and /or crooked in the hole. I finally got tired of it and did it myself, no more problems, I also used the 3M leather/vinyl kit from wal-mart to fix may linoleum and leather products, the problem with slides is they can come out of alignment real easy, some people never have a problem with them and others have nothing but problems with them.
wildcatter is offline   Reply With Quote
floor, slide
