Old 11-10-2018, 06:02 PM   #1
jacgec's Avatar
Lost power in slide receptacles
We lost power in the receptacles in the door side slide of our 38FB all of the sudden.
I traced the problem to a plug in connector just inside the frame (you have to drop a belly panel to get to it). The plug had just bounced apart I guess.
Anyway, you can barely get your hand up there between the frame and the tank to reconnect it but it can be done. It had a snap when I put it back together but I put a tie wrap on it just in case.
Here is a picture. I may be the only one this happens to, but I thought I could save you some time if it does happen to someone else.
Happy camping!
jacgec is offline   Reply With Quote
Old 11-11-2018, 06:05 AM   #2
Great tip. Thanks. Goes right to the "save" file.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
power, slide
