Old 06-02-2018, 06:30 PM   #1
No hot water to kitchen sink in 38MB
We have a 2018 Riverstone legacy 38mb with a tankless hot water heater. We usually have to fill the fresh water tank and turn on the pump to have enough pressure to have hot water in the bathroom. But I donít get hot water to the kitchen sink, even when the Hot Water panel in the bathroom reads 122 degrees. There have been a few times when I have had lukewarm water at the kitchen sink but not lately. Any suggestions?
2017 Ford F-350 dually
Lear2017 is offline   Reply With Quote
Old 06-03-2018, 05:36 AM   #2
nomad297's Avatar
You are not getting enough flow through your kitchen faucet to trigger the flow sensor in your tankless water heater. You need to increase the flow at the faucet.
Remove all water restrictors from your kitchen faucet. You can find them in several places, and many kitchen faucets have more than one. You can find them in the aerator, at any connection on the hose that leads to your spout (if you have a pull-out head) and other places ó it all depends on the type of faucet.
Bruce
Old 06-05-2018, 04:04 AM   #3
nomad297's Avatar
Did you work it out?
Bruce
Old 06-05-2018, 06:16 AM   #4
Just a crazy thought but have you checked the water manifold? Maybe the valve is off by mistake or somehow got bumped to the off position.
2017 River Stone Legacy 38mb
2001 Kenwoth T2000
2008 Smart on deck
dblr is offline   Reply With Quote
Old 06-05-2018, 09:41 AM   #5
nomad297's Avatar
I believe he has water, just not hot water.
Bruce
Old 06-05-2018, 11:05 AM   #6
Bruce
I kind of figured that but hey you never know, as my daddy use to say, start with the simple things first, but you know I never listened
2001 Kenwoth T2000
2008 Smart on deck
Old 06-05-2018, 04:33 PM   #7
Check what Nomad suggested. When we did the PDI on our 2018 38FB2 we had hot water everywhere but the kitchen sink. The tech removed the flow restrictor water saver insert and the problem was solved. Hope this helps.
Pete
Fishrsafe is offline   Reply With Quote
Old 06-06-2018, 05:58 AM   #8
Thanks for the suggestions. We took the faucet apart but couldnít find a restrictor. We are taking it in for warranty work in a few weeks and will ask them to remove it then. We did find that our water regulator was set too low and adjusting that helped. We can get hot water now but pressure is still low at the kitchen sink. Hoping that removing the restrictor will help.
Old 06-20-2018, 08:21 AM   #9
We have the same issue in our 2018 39FK...
jdmoody09 is offline   Reply With Quote
Old 06-20-2018, 08:28 AM   #10
Is your issue the exactly the same?
Do you have a tankless water heater?
Did you try the suggestions posted in this thread?
I see this is only your 3rd post... Welcome!
If your issues are not exactly those of what is described in this thread,I suggest you create a new post as other posters may not see your query. You will get a lot more help finding a cure if you create your own post.
Days Camped: '16=46 '17=30 '18=51 '19=36
hot water, sink, water
