Old 07-07-2018, 06:51 AM   #1
Preventive Roof Work
While anxiously awaiting my 38MB to be built, and since this is the "last" (yeah, right) RV I will be buying, I am thinking of things I can do to to prolong my investment. Since leaks are by far the biggest RV killer, I was thinking that upon delivery, I'd Eternabond all the roof seams. Never used it before but all my research says it works great and last forever. Good idea? Pro's/Con's? Thanks
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 07-07-2018, 09:04 AM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Search for this on Google 'love your rv eternabond'.
IMHO, eternabond is great stuff but you don't want it to be visible from the ground. I inspect the seams every few months (no fixed schedule) and have a tube of Dicor lap sealant on hand, even with eternabond covering the entire roof I would still do a regular inspection. What's just as critical as the roof is the sides of the rv, ours is only a year old and I have already resealed a few spots on the side where the fiberglass cap meets the sidewall with Proflex RV. It's just part of the routine maintenance, same as a house only different.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 07-08-2018, 06:33 AM   #3
I was meticulous on looking for leaks on My Voltage TH. I was just thinking the Eternabond on all the roof seams (not visible from the ground) might just be an extra layer of protection. I guess I'll wait and see how good of a caulking job the factory does before making a decision. Thanks.
Rusty
Old 07-18-2018, 07:33 AM   #4
I would stick it out with your new roof, and when it starts looking worn, have RV Armor give you a permanent roof with a lifetime warranty. They'll actually come to you. I have been keeping an eye on their work (photos and reviews online in social pages and forums), for over two years now, and I am very impressed. It truly is a lifetime warranty. Check it out on their website.
eadebeaux is offline   Reply With Quote
Old 07-18-2018, 08:40 AM   #5
Rubber roofs should last 10+ years easily, with proper maintenance. The longest I've owned an RV was seven years, and the roof was still in great shape. On that roof I only used Dicor.
I clean and condition mine once or twice a year with Protectall products.
I've always thought using Eternabond on every roof seam was overkill and expensive. I only use Eternabond on problem areas. Eternabond is great stuff, until you have to remove it to replace a cap or skylight
Old 07-18-2018, 09:06 AM   #6
ben31's Avatar
Eternabond is wonderful stuff. I originally got on the roof every few months with a tube of Dicor self-leveling sealant. However, this year, I started using Eternabond on the areas, which needed the touch-ups. I installed the eternabond and then used the Dicor around the edges of the tape. It might be double work, but I have been surprised at the number of touch-ups needed to keep everything from leaking and don't want anything to happen in between roof checks. I haven't gone as far as the preemptive Eternabond, though.
They make different colors, so even if it isn't visible from the ground, I still like to try to color-match everything.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 07-18-2018, 12:38 PM   #7
Perhaps ben31's method will work for me. When the roof does start to go, assuming I still have the RV, RVArmor is the way I'll go, despite the 7 grand expense.
Rusty
Old 07-18-2018, 12:51 PM   #8
Rusty
Ouch, for that much I'd just get a new RV
roo, roof, vent
