Old 04-16-2019, 05:05 PM   #1
Residential refrigerator in storage
How do you turn off your frig when in storage?
Fmunoz is offline   Reply With Quote
Old 04-16-2019, 05:14 PM   #2
prob depends on model. mine if you turn the temp knob all the way down it has an off position. also turn invertor off or disconnect battery negative, or all three.
Kimber45 is offline   Reply With Quote
Old 04-16-2019, 05:44 PM   #3
Oaklevel's Avatar
We cut the breaker off in the panel. Ours has a 15A breaker just for the refrigerator outlet.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 04-16-2019, 07:25 PM   #4
are you plugged into 110 vac power when in storage? if not, it will turn off due to lack of power. do not run it off the inverter as you will kill you batteries. if you have 110 vac power present i'd consider just letting it run. if you have power and want to turn it off there will be a control on the refrigerator that will turn it off, or as mentioned earlier. flip the circuit breaker.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 04-17-2019, 09:00 AM   #5
Jim34RL's Avatar
We have an off control button and turn the fridge off. I also turn the disconnect key off and the inverter is off. So, no power is sent to the fridge, we also leave both doors opened stuffing a pool noodle between the door opening and the rest of the fridge to allow air to circulate.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 04-18-2019, 05:12 AM   #6
Just going thru this with my Samsung. No on/off switch I could find. Just flipped the inverter circuit breaker, as the fridge is the only thing plugged into it. Didn't want the inverter running anyway.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 04-18-2019, 09:07 AM   #7
Jim34RL's Avatar
My residential fridge does not have an on/off switch either. In the owners manually for the fridge, the procedure is outlined for turning the fridge on and off. This requires you to hold in the temperature selection switch for a few seconds. The fridge will either be on or off depending on if the fridge was operational or not.
You may want to read the O&M guide for the fridge or search on line for your model. To find out how to turn this on/off.
Jim W.
Old 04-18-2019, 09:31 AM   #8
cavie's Avatar
turn off the breaker. I'm pretty sure that will do it.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-19-2019, 05:25 AM   #9
Darn, hitting the breaker for the inverter (no breaker could be found just for fridge) also shuts off my GFI outlets. A cursory review of manual (I'll re-check) doesn't mention shut off procedure (It's a Samsung). Tried hitting and holding temperature controls. No luck. Since RV is going in for warranty work and will be sitting in the lot for a month or two. I know they will re-set the breaker, which will turn on the fridge/inverter which automatically turns on my ice maker which I fear will burn out since there is no water (ice maker turns on automatically every time you turn the fridge on. Have to find a way to shut off before next week. Hello Google I guess.
Rusty
Old 04-19-2019, 06:13 AM   #10
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
This is what we did one time when our fifth wheel was going to be in for service a few days.
We are fortunate and normally we keep it at home with electricity provided year round.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 59
rjshiflet is offline   Reply With Quote
refrigerator, storage
