Old 06-22-2018, 12:38 PM   #1
Slide Out Tray for Basement
Has anyone installed a slide out tray in their basement? Since I'll have the mini-fridge, thinking about getting one that would slide out towards driver's side. Maybe 1/2 or 3/4 basement length due to mini-fridge on passenger side. Pros/Cons? Never had one in my other 5'er. Looks convenient.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 06-22-2018, 02:56 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Except, there is the compartment with the hydraulic pump and reservoir as well as the brake actuator under the floor, assuming it is the same in all RiverStone. I don't think it'd be wise to install rails over top of it and block the access.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-22-2018, 09:46 PM   #3
jacgec's Avatar
I installed a Morryde slide out tray on the door side of our 38fb legacy. I opted not to do the full slide through and did one that is 52 inches wide by 60 inches deep. It makes access to the center area really easy. Install was simple and love it so far.
jacgec is offline   Reply With Quote
Old 06-23-2018, 05:54 AM   #4
Din't know about the pump access, since I'm only working off of videos and pictures. Maybe I can get a narrower one and do what jacgec did. Thanks.
Rusty
Old 06-23-2018, 06:02 AM   #5
jacgec's Avatar
By installing from the right side I have about 36 inches of space left on the drivers side what worked out great for me because that is where I keep the hose reel, tools etc.. It also allows access to the hydraulic pump, brake actuator and water manifold.
Enjoy your new rig!!
Ed
Old 06-23-2018, 06:24 AM   #6
Sounds like a plan. Thanks Ed.
Rusty
Old 06-23-2018, 10:07 AM   #7
jacgec's Avatar
ID:	176940Click image for larger version
ID:	176941Click image for larger version
Hey Rusty, I thought some pictures might help.
Old 06-23-2018, 10:59 AM   #8
Perfect. Looks great. Just screws to the floor?
PS. Looks like I I'm getting the same color unit as yours (Merlot)!
Rusty
Old 06-23-2018, 07:49 PM   #9
jacgec's Avatar
Good choice on the paint job!! Itís a beauty!
It bolted in with 4 lag bolts. I had to shim it up about an inch so the drawer would clear the door frame.
It weighs about 150 lbs so an extra pair of hands to get it in place is helpful but I was able to install it by myself.
It sure beats crawling in there to get the stuff in the middle.
Ed
Old 06-24-2018, 02:43 PM   #10
Vince and Charlette's Avatar
You'll find it's a real back saver.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
slide, slide out
