Old 12-08-2018, 03:57 PM   #1
Riverstone 39RKFB
Towing 39RKFB Riverstone
First, we are new to the site and new owners of a 2019 Riverstone39RKFB.
My question is:
Does anyone pull there Riverstone with a 3/4 Ton Diesel? I purchased a 2019 Riverstone and will be picking it up soon. We have a 2017 Super Duty Diesel and are on the fence if this will be enough truck. Thanks in advance for the comments.
Quick is offline   Reply With Quote
Old 12-08-2018, 04:10 PM   #2
You're going to be over rated weight by a ways. Especially payload.
2017 F350 Powerstroke DRW 4x4
2013 Cedar Creek 36CKTS Custom
aknavy is offline   Reply With Quote
Old 12-08-2018, 04:13 PM   #3
Looking at the GVWR of that 5er being 19000 lbs, I wouldn't even tow it with a 1 ton Single Rear Wheel truck.
That's dually territory.
Mike
2016 PrimeTime Lacrosse 324RST
TV = 2017 Ram 3500 (aka FRAM)
walaby is offline   Reply With Quote
Old 12-08-2018, 04:38 PM   #4
Mike
Yep. It can be done with a one ton, but it's a way better ride with a dually. I've done it with both trucks and wouldn't go back to SRW.
Old 12-08-2018, 07:28 PM   #5
As has already been posted, that’s dually territory. Pin weight will be close to 4,000lbs.
Fishrsafe is offline   Reply With Quote
Old 12-08-2018, 08:33 PM   #6
Riverstone 39RKFB
Would you think Air bags on Dually would be needed or would help? I have owned 5 - 5th wheels just none of them weighing as much as this one.
Old 12-08-2018, 08:37 PM   #7
Not needed on a dually. Not sure if it would help, but definitely not needed.
Old 12-08-2018, 08:57 PM   #8
Georgia Rally Coordinator
aceinspp's Avatar
Looks like you need to up grade TV. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 67
Old 12-08-2018, 08:58 PM   #9
BandJCarm's Avatar
Heck yeah, air bags are needed. I have 'em on my dually and they help the ride a lot. I can adjust via remote, on the fly.
But they don't do anything to assist with payload or towing.
Go look at your yellow door jamb sticker. It says Cargo Carrying Capacity. I'd bet yours is around 2,500, give or take. Since I bet your pin weight is 3,500 plus or minus.........you are over payload before you even count fuel, passengers, 5th wheel hitch, or cargo in truck.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 12-08-2018, 09:09 PM   #10
Riverstone 39RKFB
As I said in beginning of thread we were on the fence about weather to keep the 3/4 ton or swap for a Dually. I am now convinced that a Dually is what we will go with. I suppose I just needed the reassurance that the 3/4 Ton would not be enough.
I have already contacted the Local Ram dealership and will be making the swap Monday for a Ram 3500 4x4 DRW.
Thanks for the quick reply’s.
towing
