Old 11-21-2018, 07:40 PM   #1
Weights....
What are your loaded weights? Model/pin weight/total weight if possible. Thanks!
2017 F350 Powerstroke DRW 4x4
2013 Cedar Creek 36CKTS Custom
aknavy is offline   Reply With Quote
Old 11-21-2018, 10:50 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
2 x 40 lbs propane cylinders full, 12 gal water heater full, all other tanks dry (maybe 10 - 20 gal water in freshwater tank), fully loaded for full-timing (food, clothes, supplies, bbq, camping chairs/table...), slide toppers, washer/dryer, dishwasher, wine fridge (not so empty ), 400 lbs batteries, 100 lbs inverter, solar panels 150 - 200 lbs, no onboard generator. Spare tire and all tools carried on the truck, actually makes for a smoother ride when not towing. I'm unable to fill all storage compartments.
15,000 lbs axle weight, 3,600 lbs pinweight.
16,000 lbs GAWR, 19060 lbs GVWR
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
weight
