Old 08-18-2019, 08:27 PM   #1
Complete power disconnect
Hello, just bought a 2020 19.8. I've noticed almost immediately that some electricity is still supplied to the camper via blue light on antenna, green lights at USB connections etc. I tripped all the breakers but still seeing the same thing.
Anyone know how to completely shut off power without disconnecting from the battery? I did a search but didn't see anything like this, just assuming it will eventually drain the battery if left long enough?
Streck is offline   Reply With Quote
Old 08-18-2019, 08:31 PM   #2
Put a disconnect switch right after the battery. I have mine on the positive side of the battery and it disconnects EVERYTHING except the battery monitor.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 08-18-2019, 08:35 PM   #3
Thank you, I'll look to install one of those. Bummer it doesn't come equipped already!
Old 08-18-2019, 08:39 PM   #4
Blackrock's Avatar
The breakers only control the 110v side of your trailer. The indicator lights you are seeing are all powered by your battery's 12v system. It's time to study up on how the electrical system on your wagon work and what the power source for all the components are.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 08-18-2019, 09:04 PM   #5
Flybob's Avatar
For an immediate solution, you can disconnect the wire on the negative side of the battery. Don't forget to reconnect before you tow. Might also check the 12V Side of Life in the forum Library ( in green bar above).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-18-2019, 09:05 PM   #6
SailorSam20500's Avatar
Are you sure your rig doesn't already have a battery disconnect? Mine came with one. It is on the street side of the trailer frame near the battery. It is not obvious - you have to crane your neck or lay on the ground to see it. Mine has a red disconnect key and looks somewhat like this: https://www.walmart.com/ip/ATV-RV-Wa...10080301008005
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 08-18-2019, 09:38 PM   #7
SlowrideHD's Avatar
Originally Posted by SailorSam20500 View Post
Are you sure your rig doesn't already have a battery disconnect? Mine came with one. Mine has a red disconnect key and looks somewhat like this
My factory battery disconnect switch doesn't stop all current flow. CO and propane monitors for example. Will drain the battery bank over time. You have to add a good true battery disconnect if you don't want any parasitic drain at all.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
power
