07-24-2019, 06:53 PM
Electrical blowing house ground fault
We plug in our No Bo 19.5 to our house 20 amp to get refrigerator cooled for the next trip. Tonight the ground fault is blowing every time we plug in the No Bo. This has not happened before.
Nothing is on in the camper, we have not turned the refrig on yet.
We checked our house circuit breaker and reset each. No difference
We used a different extension cord from camper to house. No difference
What else could be causing this?
07-24-2019, 07:03 PM
Coach
Have you used this outlet before to power your No bo? Gfi outlets don't always get along with campers.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
07-24-2019, 07:10 PM
either move the cord to a non GFCI protected receptacle in the house
or
turn off the gfci circuit breaker in the trailer
or
run the extension cord directly from the house to the refrigerator
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
07-24-2019, 07:28 PM
electrical problem
Valley duo - yes, this is the same outlet. We tried other exterior outlets with same result.
Chickdoe - We moved cord to non gfci protected and electricity stays on but were advised to not leave it this way over night.
If it is the gfci circuit breaker do we just buy a new one to replace it -- do these things go bad often?
Thanks, I really appreciate your help
07-24-2019, 07:35 PM
electrical problem
Another perspective -- just for future reference
Just spoke with another person who has experienced this with his camper. A tiny speck of moisture in the 30 Amp receptacle on the camper can cause this to happen.
On the 19.5, the outside shower is directly above the electrical input, the spout for water from the roof drips directly down to it, and I think a water input is directly above it.
Right now we are taking it out of the camper, drying all parts then will put back together and caulk it all around. Hope this works and solves the problem
The GFCI breaker is not bad. The issue is the way they work. Some of the inexpensive GFCI breakers will appear to a good one in the same circuit as a fault. Try turning off the breaker in the distribution panel that controls the GFCI protected outlets ( bathroom etc) in the RV. This should be a different circuit than the fridge is on. If you can not do this. There is nothing wrong with being plugged into a non gfci outlet in the house. The large breaker in the campground pedestal is not GFCI protected.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-24-2019, 07:37 PM
Flybob, will take this to the guys by the camper to check it out.
07-24-2019, 07:47 PM
i gotta ask! it works when you plug into a non-gfci receptacle but you were advised not to leave it this way. whose advice and based on what?
07-24-2019, 07:51 PM
Chickdoe, I asked a friend who is a mechanical engineer. He does not claim to be an expert but suggests we not leave it plugged in overnight as a precaution. Like maybe a fire could start while we're asleep. I didn't ask a lot of questions of him
07-24-2019, 07:56 PM
GFCIs are designed to prevent electrical shocks to humans. Circuit breakers are designed to protect wiring against shorts and overloads. You are still going through the circuit breaker in you home panel. GFCIs do not prevent fires.
TST Tire Monitors
2 100W solar panels
07-24-2019, 08:06 PM
You need to ask RV questions from RVers, not a mechanical engineer.
07-24-2019, 08:37 PM
you're trying to cool down the refrigerator.
the only risk of fire that i could see would be if the extension cord was under gauge.
then again, you will get a propane burner fire if you have an rv refrigerator and shut down the shore power. it will switch to propane and fire up the burner.
07-24-2019, 08:49 PM
This is simply not true. The breaker should trip. As was said earlier GFCIs are designed to protect humans. Not to prevent equipment damage.
When you plug your camper into a campground electrical pedestal. The main outlet you plug into is not GFCI protected.
At home it is always best when possible not to use a GFCI protected outlet.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-25-2019, 01:38 PM
It is fine to plug camper in to a non GFCI receptacle in the house. When you have a dedicated 30Amp RV plug in your garage it isn't a GFCI circuit and goes directly to the main box with a 30A breaker. Then the RV cord plugs into the receptacle and out to the RV. So no GFCI in that loop. So no problem.
If using a 20A receptacle going over an extension cord to the RV make sure it is a good heavy quality cord 12 gauge three prong and in good shape. Don't run over wet ground.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
07-25-2019, 02:09 PM
Wet ground?
I've never had a problem running a quality (e.g., SJO) cord over wet ground. Our smaller travel trailer has been connected to a non-GFI 20 amp outlet via a quality 10-gauge cord for five years with no issues, through rain, snow, thundershowers, and everything else.
Larry
07-25-2019, 02:20 PM
Been plugging our TT's into a non-GFI plug since 2007 and ran the refrig all summer long while they're in the driveway. You'll be fine plugging it in elsewhere.
07-25-2019, 02:27 PM
You had me agreeing 100% until your last sentence.
Why would running a "good heavy quality cord 12 gauge three prong and in good shape" (your words) over wet ground hurt anything?
07-25-2019, 02:35 PM
I just set my Rv fridge on lp gas to cool it for a day. Too much trouble to drag out extension cord and it uses a small amount of LP in that time.
Peace!
Dan & Rita D
07-25-2019, 02:54 PM
Electric motors and GFCI's don't always play well. The air conditioner in our boat house will often trip the GFCI if anything else is plugged into the same circuit.
It is always safer to use a GFCI protected outlet outside if available to prevent getting shocked.
07-25-2019, 03:48 PM
How about a no nick, no cut, perfect shape outdoor extension cord. My statement was for all those who use tired old garage extension cords that are just looking for a chance to short out. My wording can be cloudy or muddy!
24WS
FX4 Off Road (4X4)
