Old 04-29-2015, 11:01 PM   #11
Originally Posted by trbomax View Post
My only question is "who takes showers outside"?
I actually prefer the outdoor shower. In warm weather it's just nice out and it doesn't take much hot water.. not to mention it helps keep the humidity down inside your rig. In colder weather I pop up an enclosed dunny so it's nice and warm inside, but don't have to deal with all the condensation build up indoors. It's bad enough fighting condensation from my portable propane heater.
Of course.. the above wouldn't apply so much to CG RV'rs, but to each their own. I would imagine anyone with pets would welcome an outdoor shower. Quick access to cold drinking water and perfect for a nice warm bath.
rana is offline   Reply With Quote
Old 04-30-2015, 05:29 AM   #12
jawga's Avatar
Originally Posted by TN_Cruise_Lite View Post
Thanks, its not too bad. I just cut and framed the hole from the inside before I ever touched the aluminum siding. Stuck the shower in backwards to make sure it fit the hole. Then I drilled a small hole in each corner from the inside out using the framing I installed as my guide. Used an oscillating saw from the outside to connect the drilled holes. I knew it would fit the outside hole because it fit the inside hole and the siding was super easy to cut.
The shower was so easy I'm considering a window for the lower bunk now. One thing about the 195BH, it was so cheap I'm not afraid to mod it and make it my own. If it cost $50,000 I might be more concerned about resale value.
When u do the window please put up pics and info on it when u are done, i'm considering the same thing. thinking of the same size as the upper bunk window
jawga is offline   Reply With Quote
Old 04-30-2015, 06:05 AM   #13
TN_Cruise_Lite's Avatar
Will do my friend.
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded)
TN_Cruise_Lite is offline   Reply With Quote
door, show, shower
