Old 05-28-2013, 02:20 PM   #11
Originally Posted by Woolaroc View Post
Awesome thanks guys! How do you drain your hot water tank? I noticed there are 2 hoses (one Red and one Blue) almost directly above the Grey/Black dump valves with screw on caps. Are these my low point drains, and is this how I drain the hot water tank?
Yes, those are your low point drains. There will also be a drain plug to remove on your hot water tank.
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 05-28-2013, 02:48 PM   #12
Denver, CO
garbonz's Avatar
A 1 1/16 socket at the bottom of the tank, which also is your anode, at least in most units.
2017 Fuse 23T
Old 05-28-2013, 10:12 PM   #13
Derald1961's Avatar
One is a low point drain the other is your overflow. You might want to ensure they didn't pit the low point valve on the wrong line. It has nothing to do with your water heater
Derald1961 is offline   Reply With Quote
Old 05-28-2013, 10:14 PM   #14
Derald1961's Avatar
I have the Hemisphere 300 BH. It has the same set up as yours
Old 05-29-2013, 04:19 PM   #15
sequoiaguy21's Avatar
A word of caution on draining the hot water tank by removing the anode...
Be sure to relieve the pressure by pulling the relief valve lever until it no longer hisses and drains water. If you have pressure in the hot water tank while removing the anode, it will probably shoot out of the tank pretty quickly (don't ask me why I know . The anode weighs enough to create a big bruise (not to mention getting hit by hot water if you're doing it shortly after shutting it off)...
2013 Salem 26TBUD
2010 Sequoia, P3, Equal-i-zer
2 Kids
sequoiaguy21 is offline   Reply With Quote
Old 08-05-2013, 08:37 PM   #16
this is a bad setup for the overflow in the fresh water system as mine also started to flow well before the tank was actually full and it's almost impossible to haul fresh water as most of it will run out the overflow. I believe the overflow should be trapped to some extent by placing it above the level of the fresh water tank.
kbotley is offline   Reply With Quote
