Old 05-25-2013, 08:44 PM   #1
2 Fresh water drain valves?
On my 27BH I have 2 hoses under the tank. 1 has a valve that I can close but the other doesn't. The one with out started to drain water as I was filling up fresh water tank. What is this for?
2006 Salem 27BHSS
2012 F-150 SCREW EcoBoost, 3.73, Tow Package.
Woolaroc is offline   Reply With Quote
Old 05-25-2013, 09:00 PM   #2
Dave_Monica's Avatar
Sounds like the unvalved line is a vent or overflow for the fresh water tank.
Dave
Old 05-25-2013, 09:12 PM   #3
I was thinking this too but there is no way I filled up the 42 gallons in 3 minutes
2006 Salem 27BHSS
Old 05-25-2013, 09:16 PM   #4
Twisty's Avatar
Maybe it is supposed to be capped or have a valve.
Is the valved line a low point drain?
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-25-2013, 09:21 PM   #5
I would assume the valved obe is low point drain, but there isn't kutch literature in the manual.
2006 Salem 27BHSS
Old 05-25-2013, 09:23 PM   #6
Twisty's Avatar
Is it a bare water line or does it have threads or...?
2012 Surveyor SV264
NW Oregon
Old 05-25-2013, 09:31 PM   #7
It looks like the same type of hose as the valved line. No threads. About 1" away from the valved line and hanging about 4" below the tank.
2006 Salem 27BHSS
Old 05-28-2013, 11:28 AM   #8
My 312QBUD has the same set as your talking about. I assumed too, one with valve is drain and other is vent/overflow.
2003 Chevy Silverado Crew Cab 1500HD 6.0 with a Whipple Super Charger
2013 Salem Hemisphere 312QBUD TT
stomperz71 is offline   Reply With Quote
Old 05-28-2013, 01:07 PM   #9
noprobrob's Avatar
Mine as well 312qbud, I thought maybe they were supposed to be joined and maybe a clamp was missing but I went to the lot and looked at two other same models, and they are all the same separated
noprobrob is offline   Reply With Quote
Old 05-28-2013, 02:11 PM   #10
Awesome thanks guys! How do you drain your hot water tank? I noticed there are 2 hoses (one Red and one Blue) almost directly above the Grey/Black dump valves with screw on caps. Are these my low point drains, and is this how I drain the hot water tank?
2006 Salem 27BHSS
Old 05-28-2013, 02:20 PM   #11
Yes, those are your low point drains. There will also be a drain plug to remove on your hot water tank.
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 05-28-2013, 02:48 PM   #12
Denver, CO
garbonz's Avatar
A 1 1/16 socket at the bottom of the tank, which also is your anode, at least in most units.
2017 Fuse 23T
Old 05-28-2013, 10:12 PM   #13
Derald1961's Avatar
One is a low point drain the other is your overflow. You might want to ensure they didn't pit the low point valve on the wrong line. It has nothing to do with your water heater
Derald1961 is offline   Reply With Quote
Old 05-28-2013, 10:14 PM   #14
Derald1961's Avatar
I have the Hemisphere 300 BH. It has the same set up as yours
Old 05-29-2013, 04:19 PM   #15
sequoiaguy21's Avatar
A word of caution on draining the hot water tank by removing the anode...
Be sure to relieve the pressure by pulling the relief valve lever until it no longer hisses and drains water. If you have pressure in the hot water tank while removing the anode, it will probably shoot out of the tank pretty quickly (don't ask me why I know . The anode weighs enough to create a big bruise (not to mention getting hit by hot water if you're doing it shortly after shutting it off)...
2013 Salem 26TBUD
2010 Sequoia, P3, Equal-i-zer
2 Kids
sequoiaguy21 is offline   Reply With Quote
Old 08-05-2013, 08:37 PM   #16
this is a bad setup for the overflow in the fresh water system as mine also started to flow well before the tank was actually full and it's almost impossible to haul fresh water as most of it will run out the overflow. I believe the overflow should be trapped to some extent by placing it above the level of the fresh water tank.
kbotley is offline   Reply With Quote
