Old 07-27-2019, 10:53 PM   #1
chachi369's Avatar
2 slides no power 2015 salem forest river 32bhds
I have juice to everything except the slides...I know its a fuse or breaker as my wife was extending the slide then nothing.
I went through the forum and found the reset button and fuse on the front undercarriage near the battery. Replaced fuse, still nothing...I reset the small button on top but is it supposed to stay in or is it like your internet modem where you press it for 5 seconds and life goes on. The reset button did not stay in if it was supposed to.
I have no tripped breakers in the panel that I can see and there is no fuse labeled for slides.
What can I look at next before I lose my summer fun at the dealer for 45 days...
Andrew
Fallbrook, Ca
chachi369 is offline   Reply With Quote
Old 08-07-2019, 06:37 PM   #2
What happened? Can you give us an update?
campingguy is offline   Reply With Quote
Old 08-07-2019, 07:00 PM   #3
just taking a guess. does it have a remote control unit that can be used to operate the slides? if so the fuse is on the receiver / control board.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 08-07-2019, 07:55 PM   #4
SlowrideHD's Avatar
Often there are two of those resettable breakers hooked together for your hydraulic pump, if that's what you have. Make sure the little button is pressed for both of them, if you have two. Often they are joined by a little copper bus bar.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 08-08-2019, 07:33 PM   #5
2 Slide No Juice Update
So still no juice to only the slides. I am in search of the bad fuse or breaker(??).
I did press the poppit...no change
I replaced the fuse not shown in picture behind cover-plate.
The remote is working all other items except slides.
New fact...When I press the button on the control panel to extend no noise but when I use the remote a clicking does occur in the main breaker panel.
Still no juice yet but listening to your inputs. I have attached pictures for reference.
Name:	Front Beam with Poppit.jpg
Cha-Chi is offline   Reply With Quote
Old 08-08-2019, 07:40 PM   #6
2 Slide No Juice photo
2 more photos.
Name:	2015 Salem 32BHDS.jpg
ID:	211878   Click image for larger version
Name:	Front Bar Upclose.jpg
Old 08-08-2019, 07:59 PM   #7
what other devices does the remote operate? is it a lippert remote? did you check the remote receiver / controller board fuses?
Old 08-08-2019, 08:08 PM   #8
Remote operates awning, stabilizers, and outside lights. The breaker panel and fuse box had no faults or burnouts from what I saw.
Old 08-08-2019, 08:32 PM   #9
there have been a couple of recent posts about issues with the devices the remote operates. i had a problem with mine. in both cases it was a blown fuse on the control board. again check the fuses on the control board that receives the signals from the remote. the fuses for the devices the remote operates are on this control board. they are not is the fuse panel. i am saying this based upon having a lippert remote and control board. if yours is another brand this may not apply.
Old 08-08-2019, 09:21 PM   #10
HONDAMAN174's Avatar
I have a similar set up to yours. Isnít there a circuit breaker right next to the slide motor? The fuse that was in the electrical box up front was for the 12v coming from your tow vehicle- might want to consider changing that to a resettable fuse/breaker. That other breaker next to it is for the main battery power. If I go by my unit this weekend, Iíll snap a pic
Just glad to get away
Old 08-09-2019, 12:38 PM   #11
SlowrideHD's Avatar
If you get in a real jam, you could just hold a piece of jumper wire from the battery hot terminal to the hydraulic motor positive post to make it run. Or if your hydraulic motor runs but just not the slides, then hook a jumper wire to your slide solenoids. Or swap the leads that go to the leveling jack solenoid to the slide solenoid. then operate the jacks in manual mode which will actually be operating the slide solenoid.
Old 08-09-2019, 12:44 PM   #12
chachi369's Avatar
Thank you much..
Old 08-09-2019, 12:45 PM   #13
chachi369's Avatar
Gotcha...Thanks
Old 08-09-2019, 12:47 PM   #14
chachi369's Avatar
I agree that I think it's a fuse...Just gotz to find the little guy. Thank you much.
Old 08-09-2019, 01:56 PM   #15
SlowrideHD's Avatar
Sometimes it is a bad piece of circuitry on the computer board (Alta board) that fails to trigger the correct solenoid to open. That's why I suggested to move the control wire from a jack solenoid to a slide solenoid, then operate that jack in manual mode, which would actually then be triggering the slide solenoid to open.
Old 08-14-2019, 11:25 AM   #16
Still no luck.
I'm scheduled to take my trailer in next week. Been doing a lot of research and reading and wanted to post this PDF for anyone that gets a slide stuck with no power.
Old 08-17-2019, 04:24 PM   #17
Thank you for the pdf and good luck. Please let us know what they find out.
Old 09-05-2019, 03:39 PM   #18
2 Slide No Juice UPDATE...I Have Juice
Fuses replaced in Control Panel that I couldn't find for my slides. This location is not noted in the owner manual LOL. Thanks to Camping World for hooking me up and showing me. I had a 45 point inspection scheduled on the trailer and the tech showed me the location.
Here are photos for future reference:
2015 Salem 32BHDS
2013 Chevy 2500
Name:	Control Panel Location.jpg
ID:	214270   Click image for larger version
Name:	Control Panel 2.jpg
ID:	214271   Click image for larger version
Name:	Control Panel Up Close.jpg
ID:	214272   Click image for larger version
Name:	Control panel Too Close.jpg
forest river, power, salem, slide
