04-15-2018, 03:26 PM
261bhxl battery draw when sitting
Checked into draw, has 0.223 amp draw all the time ( I'm a auto tech) , last year unhooked the gas detector thinking that was it, nope.. So started pulling fuses ( yes I can not find anything on to draw at this point) , and t.v-jack fuse pulled draw drops to 0.07 draw ( good) , also note the red led for that fuse comes on with it out
Now this is going from the list ( which sucks by the way lol) , and confirmed the t.v booster ( has just coaxial cables in it and switch) port light goes out with switch on, but it's off and still drawing... With fuse out everything else I can find that needs 12v power works
Obviously there is a draw as the red led comes on with fuse out as I.ve read online, all power Jack's work and unless the 110 plug beside the t.v booster is 12 volts too, there is nothing like the older trailers that had a cigarette lighter socket
What else would be or tied into that to draw
Might just leave fuse out for now
Anyone else seen this??
04-15-2018, 03:39 PM
Who Dares, Wins
Yep, always a draw from the assorted LEDs that might run while showing 12v is present, propane sensor (as you have figured out)... Also check the radio. It will keep a draw to maintain its "memory"
2015 Chevy HD D-Max
2022 Impression 315MB
04-15-2018, 03:41 PM
DVD player will draw some current. If you have any remote operated items the remote rcvr will draw current. If you are concerned about killing battery while being store, Just add a switch on the ground side of battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-15-2018, 04:18 PM
No LEDs on when fuse in, radio still works with fuse out and only has. 07 draw ( assume that's the memory in radio) and that fuse isn't for the radio
I have no t.v hooked up or mounted, just the rca plug box, t.v booster -coax cables and 110 plug all side by side under radio in kitchen table upper cabinet
04-16-2018, 02:11 PM
I don't know what it is either but why not just add a simple disconnect switch on the negative battery terminal to kill all the draws? .223 is way too hi...roughlly 6 amp hours a day will kill a batt in 2 weeks so it's a good thing you checked it out.
Walmart has these kill switches for about 7 bucks:
________
Cam
2015 Georgetown 280DS
04-16-2018, 02:27 PM
Pain in the butt to have to take battery cover off every time, so twice every trip
Which for the most part is used only weekends
04-16-2018, 02:39 PM
Then install one on the battery box.
https://www.amazon.com/Cllena-Batter.../dp/B01IQRMGFA
2011 Traverse LT, 3.6L, FWD
04-16-2018, 02:46 PM
X2... nice work!
________
Cam
04-16-2018, 02:50 PM
Originally Posted by rockfordroo
That's better
04-16-2018, 07:13 PM
i put one on my battery from parts store that has a red plastic key that locks in when on and comes out when not engaged.
04-17-2018, 06:28 AM
I installed the same switch, but mounted on a small bracket beside the battery box. Much more convenient than the earlier switch on the post.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
04-17-2018, 12:06 PM
Installed the same one, also on the battery box, works great.
Louisiana
2017 Salem Cruise Lite 201bhxl
2019 Chevy 1500
04-30-2018, 11:13 PM
Well took it in, guess the t.v jack amp thing was bad ( knew that) , had some other extended warranty things and asked about the draw, so they checked it
Still going to put disconnect on battery just cause
