Old 05-01-2014, 11:09 PM   #11
OL Creeker's Avatar
Look at the R factor stats for a Cedar Creek. We went through a tank of LP in ONE day in temps around the mid-upper 30's. The four season capability is true - it just depends upon where the unit is during the winter!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 05-01-2014, 11:34 PM   #12
Plain Old Member
The only time we run the furnace is when it's going to freeze. Anything above 32, and it's heat strips, small space heaters front and back, and of course the dehumidifier I've mentioned in other threads puts off a bit of heat while keeping the windows and walls from sweating. We stay quite warm. Never went through a tank in a day, although we're prepared to. I'm sure we would if we used that as primary heat. We have an aux tank that sits under the front with it's own line for easy hook up.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-02-2014, 12:18 PM   #13
Boss Ox & Drovergirl
oxcamper's Avatar
Our park is near Ceaser Creek State Park (Ohio) just outside of Waynesville, about 30 or so miles north of Cincinnati right off I-71. They do offer year round sites with full hook up. I went there in February with about 8 inches of snow on the ground, the drives were plowed, and there are about 8 - 10 full timers living there all winter. Now I'm asking them how bad it was and none really had any horror stories. This was a cold and long winter in SE Ohio, but it looks like it's able to be done with some precautions.
But again the question remains do we bite the bullet and get something which, granted is not a mobile home in a trailer park, but has more insulative construction than our Hemishpere.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 05-02-2014, 01:07 PM   #14
keep camping's Avatar
Look at the Ice Castle RV Edition fish house, you still have to figure out how to keep the water from freezing, but rvalue is better than a TT
2 Happy Campers & CoCoa the camping Yorkiepoo
2005 Salem LE 19FD
2009 Ford F150 Lariat
keep camping is offline   Reply With Quote
Old 05-02-2014, 05:16 PM   #15
What R values do people think is needed for 4 Season living?
I'll be trying this in northern AL starting this summer but wish I was further north.
EdHarvey is offline   Reply With Quote
Old 05-02-2014, 06:21 PM   #16
Plain Old Member
Mark, if I were in your shoes, I'd probably attempt a season with what you have. Biggest reason, you just might buy something that is consider better insulated, and find yourself in the same boat. Just my 2 cents. With precaution, I think you'll be fine. Keeping inside warm is easy, it's the all the other stuff that tends to be a problem every now and then.
