Old 04-13-2019, 04:32 PM   #1
runner48's Avatar
50 Amp Plug
Anyone out there have any recommendations on the best plug to purchase. I am considering purchasing a generator but the one that I am considering has 30 amp plug in?
runner48 is offline   Reply With Quote
Old 04-13-2019, 04:40 PM   #2
fonzie's Avatar
Are you asking to have a generator adapter going from 30 amp male plug to 50 amp RV female plug? If yes, does the 30 amp generator female plug is straight blade or twist lock?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-13-2019, 04:41 PM   #3
cavie's Avatar
Plug for what? 20 and 30 amps is all your gonna find in portable generators. if you have a 50 amp RV then you'll have to use a 30/50 dog bone,
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 07-29-2019, 09:00 PM   #4
Champion sells a ~3500 watt dual fuel generator with native 30amp RV plug. Much quieter than most generators (not as much as a Honda). You can get two of them with a parallel kit that has a native 50amp RV plug—fire em both up and run whatever you want in your rig.
Usury is offline   Reply With Quote
50 amp
