Old 06-18-2018, 05:03 PM   #1
A/c
Our camper is one year old and now the a/c is not blowing cold air. Any ideas on why this would be?
skid is offline   Reply With Quote
Old 06-19-2018, 06:03 AM   #2
Do yo hear the compressor kick on?
Keith3679 is offline   Reply With Quote
Old 06-19-2018, 06:10 AM   #3
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
If the compressor is kicking on and it still isn't blowing cool/cold air - I'd say you've lost part or all of the refrigerant. If the compressor doesn't kick on...I'd suspect there's an issue with the A/C itself.
Short of getting an A/C technician to look at it - I'm not sure what else you can do.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 97
rjshiflet is offline   Reply With Quote
Old 06-19-2018, 06:15 AM   #4
There's 3 120 VAC wires to the AC. I know because I just ripped my AC wiring out and installed my own relays to work with my Nest in the TT. There's a Fan Hi, Fan Low, and Compressor wire. Check that you are getting 120 VAC to the compressor if you dont hear it turn on. If you are getting 120 VAC to the compressor and still not turning on, I'd say compressor is shot. If it is turning on and no cold air, it's the coolant.
Old 06-22-2018, 06:11 PM   #5
Thanks for the replies. Our camper is on a wooded lot and when I got on the roof I found leaves were pulled into the cover. I cleaned it out, and now it works great
Old 06-22-2018, 06:25 PM   #6
bubbles's Avatar
I would go on the roof and check for leaves pulled into the cover.
