Old 09-12-2019, 08:16 AM   #1
Access to Hot Water Tank
Hi, I have an REI 27, 2018. I am trying to find out how to get access to the hot water tank to winterize it? Does one have to crawl through the storage area or is there another access point.
Thanks in advance.
Genec1234 is offline   Reply With Quote
Old 09-12-2019, 09:08 AM   #2
I would think it is accessed under a bed/bench/couch or whatever is above. Like on mine, I have a futon couch that I lift the base up as if converting from couch to bed and I can take a few screws out of a plywood cover to expose the water heater assembly. That is where the valves are to isolate the tank. Take a look inside at whatever your floorplan has over it, you likely have a way in from there.
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is online now   Reply With Quote
Old 09-12-2019, 09:16 AM   #3
You access the valves under your bed. You lift the bed to find the panel that you remove. I used some "Google-Foo" ninja skills to find that.
Old 09-12-2019, 09:23 AM   #4
I found a photo of the access panel on a new 2020 "version 2" model, but yours is likely the same as the water heater is still on that left front corner on this 2020. Lift your bed, the panel on the left side as your looking forward.
Name:	Forest River Salem 27RE Travel trailer (version 2) - Internet Explorer.jpg
hot water, tank, water, water tank
