Old 05-08-2016, 11:13 AM   #1
AM/FM radio reception
I been searching this issue for a while but have not yet found the definitive answer.
In my 2014 27RKSS there a Jensen stereo system. I can't seem to pick up any radio statins but I can from my vehicles while sitting right next to the trailer.
It seems as if there's not an antenna hooked up. The only antenna on the roof is one of those big wing thingy, (not sure what they're called). Is that supposed to be an antenna?
There's a guy who camps next to me in a 26TBUD with an antenna that looks like a car antenna and he get radio just fine, also other trailers around with similar set-up and it works just fine.
What if anything can I do to get radio reception? I have a car antanea that I got from an old scrapped car that I hooked up but with no luck. I just plugged it in to back of stereo and tried it. Does it need to be grounded to work?
2014 Salem 27RKSS
Burgeogull is offline   Reply With Quote
Old 05-08-2016, 12:16 PM   #2
This is what I have from a wrecked car.
2014 Salem 27RKSS
Old 05-08-2016, 12:19 PM   #3
Iwannacamp's Avatar
I bought a indoor am/fm from eBay for $5...worked fine. I put it inside the cabinet by the radio. Looked like an led light strip.
2017 Puma 297RLSS
Old 05-08-2016, 12:19 PM   #4
You have to turn. On the antennae booster just like over air TV. I can't even pick up the transmitter 3 miles away without doing so. I have the omnidirectional UFO on my roof.
2016 Grey Wolf 26DBH
Ram 2500 5.7 Hemi 4WD
gconley is offline   Reply With Quote
Old 05-08-2016, 12:21 PM   #5
Turn on? How? Is there a switch or something I don't know about?
2014 Salem 27RKSS
Old 05-08-2016, 01:00 PM   #6
There should be a small button next to where your cable connects. A small blue or red light will come on. Keep in mind when connected to cable it will cause bad interference.
Old 05-08-2016, 01:18 PM   #7
This what my entertainment section looks like. No switch. One plate has 2 cable connections, I assume are satellite and cable, then there's the other RCA plug one.
2014 Salem 27RKSS
Old 05-08-2016, 01:27 PM   #8
Left Coast
Let us see what the 'thingy' on the roof looks like..
Old 05-08-2016, 01:50 PM   #9
I not close to my trailer right now but here's a pic I found on line. Can't move it either way, up or down, or right or left.
2014 Salem 27RKSS
Old 05-08-2016, 02:04 PM   #10
You should have a booster switch somewhere. What year model trailer is that
Old 05-08-2016, 02:05 PM   #11
I have seen them at your switch panel on some of the units.
Old 05-08-2016, 02:06 PM   #12
I see 2014. It's got to have one. I'll research your trailer stand by.
Old 05-08-2016, 02:06 PM   #13
Iwannacamp's Avatar
Radio or television?
2017 Puma 297RLSS
Old 05-08-2016, 02:12 PM   #14
It's a 2014 Salem 27RKSS
2014 Salem 27RKSS
Old 05-08-2016, 02:16 PM   #15
I am trying to get radio, I have satellite tv.
2014 Salem 27RKSS
Old 05-08-2016, 02:20 PM   #16
Bako88fan's Avatar
Is there a small button switch where you plug in your bedroom TV?
If you can't find a switch, you may need to pull the head unit. There's a good chance the factory missed hooking up the antenna to the radio.
2008 Wildcat 29RLS
2016 Chevy Silverado 2500 HD
4x4 z71 Crew Cab Duramax/Allison
Bako88fan is offline   Reply With Quote
Old 05-08-2016, 02:24 PM   #17
Can't remember now! Don't think so though. In the bedroom I know that there's a spot for cable to screw on.
2014 Salem 27RKSS
Old 05-08-2016, 02:27 PM   #18
Bako88fan's Avatar
If you have a switch, that's your antenna amplifier.
May have to pull the head unit and see if the factory missed hooking up the antenna or maybe the antenna slipped out of the port. That's a fairly easy fix.
2008 Wildcat 29RLS
Old 05-08-2016, 03:13 PM   #19
I'll have to check next time go to my camper.
2014 Salem 27RKSS
Old 05-08-2016, 03:39 PM   #20
It could be next to where you extend your antenna. The TV antenna also works your radio.
radio, reception
