Old 06-07-2013, 01:59 PM   #31
So, I finally got an answer.... Ie I had to call them and wait on the phone till I got an answer... :-) But I got one none the less. They tell me that is totally normal for that type of power awning and that is as closed as they get. He thought it weird also but they looked at 3 others on the lot and all were the same. He is going to send me pictures of the other ones so I can see for myself.. Seems like a cruddy design, but I know diddly about designing awnings on campers so who am I to judge. ;-). I got up there and honestly I cannot figure out how it would be possible for it to close any more than it is with those big black plastic motor caps on there. There is no recess in the back of them, so I guess I move on. Thanks for all the help and suggestions fellow campers.
Kdz300 is offline   Reply With Quote
Old 06-07-2013, 02:06 PM   #32
If you get the pics and they are the same as yours, I would definitely install a lock similar to what I did. That motor is going to be under a constant load trying to unroll all the time you are towing and with the problem Dometic had with some of their awnings, it would be worth the effort to lock the roller from turning while towing. I think I would still try to get the dealer to re-mount the arm supports lower on the trailer to get the top of the roller at least down level with or slightly lower than the mounting rail.
Old 06-15-2013, 12:31 PM   #33
This is the same awning I have on My 2013 Hemisphere. I just noticed couple days ago that the rail that holds the awning material is pulling away from the camper. Just at one end maybe a foot and half the end. Mine looks just like yours with the roll tube being above the rail mount when closed. I thought to that the side rails should be mounted maybe 2" lower to let the tube roll in another turn and be level with the rail. Mine gets to full in(closed)position and is still pulling hard on the awning material and the side arms look to be all the way up against camper. Kinda scared to even take mine down the rode right now the way it is, the place that its pulling away is to the front of camper. With that much awning material still hanging out their it has to be allot of stress on the rail and electric motors trying to hold it in.
2003 Chevy Silverado Crew Cab 1500HD 6.0 with a Whipple Super Charger
2013 Salem Hemisphere 312QBUD TT
stomperz71 is offline   Reply With Quote
Old 06-15-2013, 12:47 PM   #34
If there is no help coming from the awning mfg or FR, I would definitely be investigating and designing something to get the motor/roller closer to the side of the camper. If not modifying the upper portion of the arms, I would devise an alum. wedge to tilt the motor/tube in to the trailer side and lower it at the same time. Might be to cut the arms off and angle cut the end and heliarc the end back on.
Old 06-15-2013, 01:43 PM   #35
I thought about leaving the side arms that are mounted to the camper in their place and just move the the arms that hinges out down about 2". That arm just has two pins that hold it to the arm that is mounted to the camper. Would just need to drill two new holes 2" lower and remount. Doing it this way their would be no holes in camper side to patch or any new holes to drill in camper. Probably sounds easier then it will be.
Old 06-20-2013, 06:41 PM   #36
I took the time to lower the side rails on mine today and it worked out real nice. Looks allot better when rolled in. The top motors are now somewhat flush with the top of the camper roof line, where before the motors were sticking up some. When rolled in the fabric is now pretty close to level where it mounts to camper instead of being higher on he roll tube side. When rolling it in the way it was before, once it got all the way in it was pulling up real hard on the fabric mount(camper side) because the roll was to high. Being 2" lower now, the side arms bottom out against camper right about the same time the roll meets the camper. Doesn't seem to be pulling on the fabric mount near as hard now. Even with it being 2" lower, still plenty of room at top of entry door to open and close with out rubbing. Have some pics on my phone after the mod. i'll see if I can post them.
Old 06-20-2013, 09:22 PM   #37
Cool, interested to see those pics. Thx
Old 06-21-2013, 02:43 AM   #38
Witch Doctor's Avatar
I wounder why FR did not do that? I'm glad you got it fixed...
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-21-2013, 04:11 AM   #39
Not sure why. It did work the way it was, but I think with it lower it will last allot longer. I'll try to post some pics when I get home.
Old 06-21-2013, 12:26 PM   #40
