Old 08-10-2019, 08:17 PM   #1
runner48's Avatar
Awning Light
My awning light stopped working, do the lights have a fuse somewhere that could have burned out or could it be something else. It was working fine. I appreciate any guidance on this. Salem Hemisphere RLBHK2368
runner48 is offline   Reply With Quote
Old 08-11-2019, 11:15 AM   #2
SeaDog's Avatar
With the awning extended follow the wires from the light that are located in the operating arms the plastic inserts should come out easily to allow you to check for an inline fuse or bad connection. Let the forum know what you find.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-06-2019, 02:28 PM   #3
runner48's Avatar
Well finally had time to trace the awning light wires, I located the 2amp fuse behind the dresser in the bedroom, I did not have to remove the left lower drawer to get to the rubber fuse box. I replaced the fuse and was back in business. Hope this helps out is your awning light ever goes out.
awning, light
