Old 03-18-2015, 09:04 PM   #1
Awning stabilizer porch light and slide out only work on battery
2013 Salem 30QBS had water damage and now nothing inside will work off the battery just the outside power option will and these same items will not work with shore power. Everything inside will work with shore power. I replaced the power inverted with a new 55amp of the same make but still no different. under the fridge is a circuit board and it did get wet but not sure what it is for or what its called any help would be greatly appreciated.
ed_r is offline   Reply With Quote
Old 03-19-2015, 07:10 PM   #2
Any help would be deeply appreciated
Old 03-24-2015, 06:56 AM   #3
Stormrider151's Avatar
The circuit board you are referring to, does it have fuses? If so I would check those. Also if it got wet I would check all of the connections for corrosion. My 2015 has something similar in the compartment with the water pump (seems like a really dumb place to put that). That may be your problem.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-24-2015, 07:27 AM   #4
Thanks for the response. It was breaker under the trailer all is good now
Old 03-24-2015, 07:32 AM   #5
TURBS's Avatar
I was going to post about checking the breaker seconds before you posted.
Glad you got it.
awning, battery, light, slide, slide out
