08-09-2016, 07:24 AM
Bama's Rambling Mods.
We purchased a Salem 29RKSS Fifth Wheel, and like most people, there are things we wish were different, and things that should have been there from the beginning.
I'm starting this thread to document the changes and additions to the RV.
08-09-2016, 07:31 AM
The first mod was the pass thru drawer.
I built a drawer for our last RV, and it was so handy that it was a must for this one.
08-10-2016, 07:23 AM
Here is a look at the terminal end of one of our A/C ducts.
You can see how they just pinched the sides in and collapsed the duct in on itself.
They left holes in the other end that I'm going to fill with foam.
08-10-2016, 07:59 AM
Happy Camper
I assume the drawer(s) is(are) a custom job. Do you have a drawer for each side, that meets in the middle?
2021 Forest River Sabre 37FLL
Towed with 2019 Silverado 2500 HD
B&W Turnover Ball Gooseneck hitch
Anderson Ultimate Connection 5th wheel hitch
08-10-2016, 10:41 AM
Yeah, the drawer is custom made by me. It's one long drawer that will pull out either side. I debated making two drawers, but opted for the one long one so I can store stuff that crosses the center line. Also, the half that's still in the rails helps counterbalance the part that's outside the RV. That way I didn't have to buy two sets of those $500.00 full extension drawer slides.
Gotta go campin!
08-11-2016, 07:04 AM
Nicely done, what materials did you use?
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded )
08-11-2016, 07:12 AM
I've made several of those using garage door tracks and rollers.
08-11-2016, 09:48 AM
The box itself is made of dimensional lumber 1x and 2x ripped to the sizes I needed, and 5/32" luan paneling. I used the materials I did to keep it as light as I could and still hold up. It's all stapled and glued together.
The rails are made of 2x4's with ripped down 1x2's glued and screwed to them to accept the nylon garage door rollers. I used that because it's what fit perfectly inside the pass-thru and would support the box when loaded and extended a little more than half way out the RV.
Gotta go campin!
08-11-2016, 07:59 PM
I received the adjustable air conditioning vents today. So I went out and installed a couple.
Here's a comparison of the new and the original.
And here it is installed. Opened and closed.
08-11-2016, 08:06 PM
Great mods! Do you have a source for the a/c vents? TIA
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
08-12-2016, 05:24 PM
I ordered the vents from D&W Inc. They're the 8850 Large RV A/C Ceiling Vent. I bought the 7/8" insertion. They fit the existing base ring perfectly.
Gotta go campin!
08-12-2016, 05:56 PM
Thanks!
Lee and Anne
08-13-2016, 07:00 PM
Did a little more investigating in the A/C ducts today.
Here's what I found.
This was found right past the bathroom vent.
It's slightly compressed and as you can see, the ends don't match. It's taped on the outside so it's probably leaking a little, but not too much.
I'm going to build a thin aluminum support to fit inside the duct to expand it back to full size and make the ends match. Then I will tape over it.
08-13-2016, 07:07 PM
All the rest of the ductwork is in really good shape.
The ducts are about 2-1/2" X 9". So that's >18 Sq in X two equals 36 Sq in of duct area, which is plenty if it's all open and there's plenty of vents.
Gotta go campin!
08-22-2016, 07:29 AM
More mods this weekend. Adding a couple of cabinet doors and a few drawers that should have been there from the beginning.
Before ;
After;
The cabinet doors don't quite match, but after a little color polish they will.
The furnace return grill is getting moved to the side of the cabinet where it should have been to start with.
09-09-2016, 04:08 PM
Finished the dinette drawer today.
