Old 10-03-2018, 06:10 PM   #1
runner48's Avatar
Bathroom Vanity Faucets
I was wondering if you could replace the plastic vanity bathroom faucet with one that you purchase at a hardware store, or a specific bathroom faucet for RVís? I own a Salem Hemisphere 2017 368RLBHK.
runner48 is offline   Reply With Quote
Old 10-03-2018, 06:19 PM   #2
bubbles's Avatar
I'm pretty sure the delivered plastic vanity faucets with RV's are 4" on center connections and any vanity faucet should work.
Old 10-03-2018, 06:21 PM   #3
I did. It was a bit of luck, but I found a better countertop to replace the factory cheap Formica covered particle board. I bought a nice bath lav set and it worked, without anything else.
I thought I might at least have to buy what I needed to adjust the pex to fit, but I simply connected the original plumbing to the new faucet, and it worked fine.
katkt is offline   Reply With Quote
Old 10-03-2018, 06:48 PM   #4
D W
D W's Avatar
Replaced both my kitchen and bathroom faucets with Peerless brand from Walmart. Kitchen is an 8" center and bathroom is a 4" center, just like residential faucets. The connectors on the PEX are the standard 1/2".
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
1984 CHEV SCOTTSDALE K20 2GCGK24J0EXXXXXXX (Chevrolet Legends-Class of 2019)
D W is offline   Reply With Quote
Old 10-03-2018, 08:14 PM   #5
WFD
I did it in this trailer as well as previous one...cheap plastic factory ones were squeaking from day 1 and felt like garbage...went to Home Depot and replaced with a residential one, 4" center...quick and easy.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-03-2018, 08:45 PM   #6
We changed the bathroom vanity faucet to a single lever Moen,"Buy it for looks,Buy it for life"! Youroo! !
Old 10-04-2018, 08:16 AM   #7
I didnít intend to muddy the water by mentioning replacing the countertop in ours. My plumbing came straight up, and didnít have any slack in the pex. I was worried switching the top, may have messed with the elevation, and prevented the new faucet set from being tightened properly. It was a direct swap.
Since I swapped the countertop/sink(a resin preformed unit))I had just enough room to install a new drain assembly also. I was able to ditch the drain plug, and go to the typical push and pull drain rod sliding up through the faucet set. The whole thing was a big plus.
Old 10-04-2018, 08:21 AM   #8
Any household faucet will work just like those at the big box stores or plumbing supply places.
The only thing R/V specific about the faucets is they are inexpensive plastic in most cases. (cheap) Replacing them is usually one of the first mods people come here to post about.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 10-04-2018, 08:58 AM   #9
Yep, Easy Peasy. I replaced all mine, kitchen, bathtub, bathroom sink.
Decon Blue is offline   Reply With Quote
Old 10-04-2018, 04:12 PM   #10
runner48's Avatar
Thanks for the feedback
bathroom, faucet, roo
