Old 07-18-2015, 03:24 PM   #21
clr
I cannot tell from the picture what group size your old battery is. Most of the RV dealers use group 27 since they are a few dollars cheaper than a group 29 battery. Most Interstate batteries are marked with the group size on the battery.
You have picked a group 24 one size smaller than a group 27. I would go with the group 27.
clr is online now   Reply With Quote
Old 07-18-2015, 03:25 PM   #22
wifeytojosh's Avatar
Sorry to be a pain the you know what. First timer here......
wifeytojosh is offline   Reply With Quote
Old 07-18-2015, 03:26 PM   #23
The 27's they have don't look like it would fit in our existing battery box. Do I need to worry about that?
Old 07-18-2015, 03:28 PM   #24
This is the top of the old one Click image for larger version
Name:	ImageUploadedByForest River Forums1437251271.182250.jpg
Old 07-18-2015, 03:31 PM   #25
clr
Well I would say your old battery is a group 24. Your battery box should also fit a group 27 most do but we cannot be sure.
Old 07-18-2015, 04:02 PM   #26
I ended up getting a group 24. I live pretty far from walmart so didn't want to risk it. Our trailer is really small. Does that make a difference in which battery should be used? We have a 20 footer
Old 07-18-2015, 04:19 PM   #27
clr
The size of the trailer does not really determine the size of the battery only the load you will be pulling out of the battery. When you get home make sure you put the battery on a charger and charge it up good before you install it in your RV. Also make sure the battery connections are clean, shiny and tight when you install.
Old 07-18-2015, 04:31 PM   #28
If I hook it up on the rv and plug into a 110, will it charge it that way?
Old 07-18-2015, 04:32 PM   #29
clr
Yes the converter in the RV will charge up the battery.
Old 07-18-2015, 04:45 PM   #30
Perfect! We don't leave until next Friday so I want to see how it all works before we leave.
battery
