Old 07-19-2015, 06:51 PM   #11
wifeytojosh's Avatar
It was reading 12.8 connected to shore power and unplugged from shore power
wifeytojosh is offline   Reply With Quote
Old 07-19-2015, 06:53 PM   #12
Herk7769's Avatar
You may have blown the current limiter that protects the battery when you unhooked the old one or connected the new one.
Look for one of these; they have a reset button on the side.
Some have a red rubber cap for protection.
ID:	83392   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 07-19-2015, 06:54 PM   #13
Herk7769's Avatar
Also check your ground; it could be why your old battery was not charging as well.
Name:	Horst Probe Install 017.jpg
Old 07-19-2015, 06:58 PM   #14
Is the reset button on the battery?
Old 07-19-2015, 06:58 PM   #15
clr
Well if it is reading 12.8 volts the battery is fully charged and therefore not the problem. Make sure that the battery is not connected backwards in the RV, positive from the battery should be going to the coach main converter fuse panel. The negative lead from the battery is connected to the frame of the unit and you can normally see where it is connected to the frame close to the battery. Also make sure that if you have a battery disconnect that it is not operated cutting off the battery from the coach.
clr is offline   Reply With Quote
Old 07-19-2015, 07:00 PM   #16
The ground is good. We have checked.
Old 07-19-2015, 07:01 PM   #17
clr
Follow the positive lead from the battery and you should find the fuse you are looking for and the reset button. On a travel trailer many times the fuse is on the underside of the frame going to the coach.
Old 07-19-2015, 07:02 PM   #18
Herk7769's Avatar
No its on the side of the current limiter (the little button on the side).
The current limiter may be under the frame near the metal box your umbilical cord goes into.
ID:	83398   Click image for larger version
ID:	83399   Click image for larger version
Old 07-19-2015, 07:04 PM   #19
Ok, let me go check
Old 07-19-2015, 07:09 PM   #20
Have white(negative) going into the frame and red(positive) going into the rigClick image for larger version
Name:	ImageUploadedByForest River Forums1437350970.562908.jpg
battery
